-   -   ***brushless Motor Overheat*** (https://www.rc-monster.com/forum/showthread.php?t=14321)
Sammus 09.01.2008 07:37 AM
Yeah sounds undergeared to me too.
Jason 09.01.2008 09:49 AM
ok ... and whats about the symptoms of overgeared ?
coolhandcountry 09.01.2008 11:22 AM
They are Fairly close. Ussually the esc will be cooler then motor on undergeared. Esc gets hot on over geared. Always exceptions to rules though.
Jason 09.01.2008 11:35 AM
I run 19t pinion 87t spur dont think it is under or overgeared on 2s 7.4v ... my e-firestorm 2wd stadium truck complete with battery/body into it is about 5lbs... esc are like about 120 to 130f and motor 180 to 195f ... battery are cooler ...
jayjay283 09.01.2008 11:50 AM
why dont you start from the beginning of your thread and reread
Jason 09.01.2008 12:01 PM
I know but I always got the same problems ...
jayjay283 09.01.2008 12:02 PM
Have you tried a 25t pinion ? according to your thread the highest you went was 19, I run 30/74 on a similar setup and it only gets hot after long runs because its overgeared
Jason 09.01.2008 12:04 PM
I tried 23t pinion it is the biggest I have in my hands and still same...
jayjay283 09.01.2008 12:12 PM
well if you use a 23T pinion and your 84t spur and the motor is still burning hot you probably cooked it and demag'ed it. http://www.rc-monster.com/forum/showthread.php?t=14381
Jason 09.01.2008 12:27 PM
hmm I opened it and still magnet so very fine on the inside of the motor can ...
Jason 09.02.2008 02:47 AM
maybe this can help you out guys --->
http://img37.picoodle.com/data/img37...1m_4c3a73b.jpg
http://img37.picoodle.com/data/img37...2m_d685b85.jpg
Jason 09.03.2008 11:20 PM
:neutral:
