that`s good to know about the ez-run being better than the sidewinder!
I guess I'm going to go with my first idea and try two ez-run 60a esc and 2 hobby city 8s feigao clones! I'll experiment with that set-up and if something goes poof at least it will have cost me only 160$ total! but if it does work...\ 160$ for a twin brushless set-up... :O) |
Go for it. I think you should run at least L motors though to keep temps down.
dont forget i`ll be running 2 of thoses S cans! i`m already running one L can and it`s already anough for the truck! it a gorillaé tryggy style maxx and pretty light... dont you think 2 L would be overkill? i'm not going for 60mph spped runs here... lol just want a reliable light 4s (2sx2) system for my truck but with the cool factor also... with 8s 4400kv they should be pretty cool running at a max of 35000rpm and splitting the load betwen them... dont you think guys...
Two L size motors would not be over kill to me. If you get 2 8L's you would have a cooler running setup.
Interesting dilema.
Since the vxl motors are something like M can, and 2 of those can achieve 60mph on 2x 3s lipo @ 3500kv, then a pair of S cans on 2x2s each should do 40mph easily enough @ 4400kv. Like you said, a single L can is enough power for you, so a pair of S cans should be about equal in that respect- just added cool factor from the twin BL layout. If you wanted to go for higher speeds, L cans would be better ofcourse... |
Personally I'd go with 2 s cans.
I still say L cans.
VXL motors are considered smaller than s size motors?:surprised:
thanks lincpimp! that's what I tought also about the L cans! not high enough kv to use only 2s. That's why I choose 8s because I want to run 2s and have a good set-up... so 35000rpm seems the ideal choice
I tought I would gear it for about 40mph and see from there... I tought of a 24/72 pinion/spur combo gives me 14.7 ratio with 5.5" truggy tires should be ok What do you guys think? Is that gearing to high? |
Ok thats why you are going to use 2 s cans. I guess i didn't under stand before.
no problemo traxxasbasher13 :O)
| All times are GMT -4. The time now is 11:26 AM. |
