Patrick |
But I would assume late July time frame is fairly accurate. |
:party::yipi::yipi::yipi::yipi::party:
finally, a Castle motor I can use to replace my 1512 1.5y btw, Neu downgraded their rating on this motor from 1900 to 1850 a while back. I wonder how much different the CC motor will be? Patrick, is it possible the 1800kv is under rated? |
If you could also do 4mm mounting holes right next to the 3mm ones, that would be great as well. |
Very nice, thanks Mr C!
3/4mm holes would be a smart move too... |
I would also like to see 4mm mount holes, both in 25mm circle and 30mm circle. With the CC/Neu motors it would be as simple as offering different front plates that can be swapped out by the end user. I personally think that M3 thread bolts are a bit small to hold up the large brushless motors.
4mm would be awesome for sure. Especially on the 1515 and up series motors.
Patrick, what kind of pricing is expected on the 1518 series versus the 1515 series? |
4mm is whay Losi uses for their motor mounts, it would be a good idea.
+1 on 4mm holes. +N on lower KV options for I have only 6S packs for both my buggy and Truggy.
| All times are GMT -4. The time now is 07:13 AM. |
