I ended up buying another crt.5 and then sold it so I could get a RC10 T4 :whistle: I really think they need a 12 step program for RC You have a good point about crawlers. It's a must to have a good motor though. I'm sure a HV or purple feigao motor will have cogging issues. |
Both ESC Prices are comparable Both ESC PC programming and updates are comparable MMM Pro's over SP - MMM Can handle up to 6S Lipo VS SP 4S Lipo max - MMM has a slightly smaller footprint - MMM has a 5AMP BEC vs SP 3AMP BEC (this won't be an issue unless you plan to run some major current drawing servo's) SP Pro's over MMM - SP runs both sensored & sensorless motors (Sensored in dual mode) - SP comes with a hand held programmer that you can use anywhere without the need of hauling around a laptop - SP On/Off switch is FAR superior to the MMM switch. The MMM power switch is notorious for switching off when the vehicle takes a hard hit. This has happened to me numerous times and I finally shoegoo'd my MMM switch to the On position. This obviously isn't a hard selling point but a small notch in the belt for the SP. |
Oh BTW,
I will be getting a RX8/2050 combo as soon as I can So I'll be able to make a comparison between all 3 ESC's soon |
Now I would like to see a decent sensored esc with 3s+ capability in a small footprint capable of 60-80amps cont. And some purpose built sealed can outrunners with high qual materials and a sensor too. Run them sensored only and they would be the ultimate in slow speed control and low speed torque. |
For me, the juries out until I get my hands on the RX8. P.S. Yes I like the LCD programmer very much. Thanks for asking... People have been asking for hand held programmers a long time. It's nice to see a company finally listen to what the public wants. It's too bad you don't work for Castle because they could use some of your insight |
Now the RX8 is a nice system. I've done a modification to one of my 4 pole Sensored Aveox motor and it worked out very well when I used it with my 10th scale ESC. Good thing a company saw the benefits of a sensored 4 pole system other then Aveox which no longer involves in RC. |
:lol: :lol: just kidding those were the days, eh? Less smart guys around back then... |
Thanks for your response. I am intending to use the esc in a monster truck. Which esc can handle heat better? Same setup (speed, vehicle, motor, cell count... etc)different esc. Which esc will run cooler? |
Wow, I think this thread got much better over night.
Glad the hostilities subsided and everyone is happy again! I remember you too starscream, I actually was on this site when it first started under a different screen name. After the collapse I never could get the old account back. |
your answer is the tekin RS run an external bec and cap and they are great on 3s and 4s.....ive been running mine in my T4 and slash on multiple different motors (8.5 sensored-2s, 10.5 sensored 2and 3s, and feagio 9l - 2 and 3s) it is an amazing litte (actually tiny) ESC, ive enjoyed it so much in the past month i bought another last weekend :yes: the tekin redline sensored motors are also great (had 8.5 on 2s geared for 40mph in a t4 and ran two 5000 packs back to back (40 solid mintues on the track) and the esc had 4 lights out of 7 and the motor was 141 :gasp: |
So, if the SP ESC is basically the guts of the 80amp unit that RCM sells, where can you get the outer case? What exactly is different between the two?
| All times are GMT -4. The time now is 10:26 PM. |
