I noticed toughracing putting 9 more ESC on ebay.
I found these pics again on photobucket. The heatsinks says plasma and the one Lutach mentioned was Plasma II. I'm guessing that the SSB I have is a Plasma and the Plasma II are the low profile versions.
http://i211.photobucket.com/albums/b...uarkplasma.jpg http://i211.photobucket.com/albums/b...arkplasma2.jpg http://www.rctech.net/forum/attachme...esc-image3.jpg |
Vid as promised.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/T9J3J9DqgM4&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/T9J3J9DqgM4&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object> <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/pzrm9cIAE4s&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/pzrm9cIAE4s&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object> |
You know this will be killer until Castle comes along and spoils the fun.
Did his auctions get pulled? i checked and there is nothing under tough racing
type in qaurk esc and it should pop up. Seller is nowingu.
I found a Korean friend who has been able to contact Quark. I may be able to start importing them again if Fedex costs are not too prohibitive.
Sounds good JRH. $122 is a whole lot cheaper then a new mamba max or tekin rspro.
True that the mamba can be purchased for ~130,-, but after adding a fan and additional caps to run a 2.5T motor properly, it's not such a bargain anymore. You get into the Mamba Monster price range and that esc is just too big for 1/10. Takes up too much real estate. It is alot easier to program a Tekin or the new quark in the field.
Any updates on this esc? Has anyone tried 6s?
What is the cell rating on the SSB?
Mine still runs strong. I only run 3s A123 with it and haven't used it with anything higher than that.
| All times are GMT -4. The time now is 07:26 AM. |
