nothing looks bad but i cant see anything that is under all that electrical tape
Electrical tape gets really gummy and messy, especially when it gets hot. Unfortunately, I can't think of anything else to use that would be easily removeable short of encasing the whole thing in a box and sealing the wire entry points while providing cooling for the heatsink.
Thanks again for the reply |
Was yours new when it died? At least you got to crash it first. I have only done a few speed runs on pavement. :012: |
I don't know if this make a difference, but I just hooked up the stock titans and esc and it ran like a champ. Motors and controllers were barely warm after a solid 15 minute session.
The good news is that the new chassis and shock position work extremely well!!!:027: |
Hey bigabike is this the same problem we talking about on the other thread.
i think your motor is the problem.
Have you took your motor apart and made sure the winding hasn't come loose in the motor. I had a motor started cogging and missing like yours. It was after a real bad crash. I kept the magnet or rotor for a screw holder. :D The motor will tap apart pretty easy. Just to let you know.
Thanks for the idea. I'll let Mike look at it. I have messed up enough stuff already. Thanks again! |
Well it is not hard to do it. I did one by accident. The motor slipped out of my hand hit the floor on the end shaft and boop it knocked the end bell off.
| All times are GMT -4. The time now is 08:12 AM. |
