thats great, make your own thread!:035:
Does maxamps have any sort of return policy? What taps do you recommend? |
Maxamps has very good customer service, undoubtedly one of the best out there.
If you're going to be using the Hyperion LBA6 balancer, then you can get the Hyperion balancing taps. As far as 48amps goes, that is the continuous rating. Your truck will only require ~23amps average, but will pull more in bursts. These cells are rated at 64amps burst for 10 sec., and can handle even more in shorter bursts (spikes). In 1p they will be plenty, especially since you're using a pretty high voltage setup. |
If thats true, then why are emaxx controllers rated for 97+ amps?
good question. to be honest i have no clue:032: :007:
same here no idea :032:
i would like to know the exact reason myself |
maybe we have been getting ripped off...:013:
It's for the high burst capability, as well as for heat issues. The MOSFETs used in the controllers are rated for a LOT of amps, but that's at 25 degrees C. At their rated number of amps, they are going to get hot, which is why heatsinks are used, but they will still heat up, making them less capable of handling as many amps as they are rated for.
WHERE DO YOU GET ALL THIS INFO!!!!!:confused:
I've read several datasheets on some MOSFETS, and picked up various info. It's all about the time ;).
| All times are GMT -4. The time now is 02:49 PM. |
