Will I be correct if I say that a 4 pole motor makes use of its rotor's magnetic field better than a 2 pole even if the magnetic mass are the same?
Can't be apple to apple. 2 pole against a 4 pole. Rotor size differences, motor wire gauge difference, etc.
If you drive enough with both of type of motors regardless of kv, you can tell a difference in behaviour between the two. |
So 4 pole better or more poles better?
| All times are GMT -4. The time now is 02:20 PM. |
