-   -   UE 8 spyder diffs (https://www.rc-monster.com/forum/showthread.php?t=2474)
neweuser 03.03.2006 04:45 PM
On another thread, captain was having diff in installing his dif's. Are there any out there that are strong that don't need so much modifying? and still cost effective?
coolhandcountry 03.03.2006 05:30 PM
I have the flm hybirds and ofna diffs. It was put together operation. I didn't have to mod nothing.
neweuser 03.03.2006 05:43 PM
thanks sounds good, are they tough enough, and what if i wanted to go duel bl later?
neweuser 03.03.2006 05:46 PM
Also, did you go to 6 spyder? or 8 spyder, when u say ofna i'm assuming that's what you are referring to...
coolhandcountry 03.03.2006 05:56 PM
I got a 8 spyder diff made by ofna. You don't need a dual brushless system. One good system will out perform and run longer than a dual. I have zero problems with the set up. I run the ue 6 spyders and the ofna 8 spyder setup with no problems.
luvsrc 03.04.2006 12:11 AM
thanks for the reply guys so $240 for both the front and rear is not bad at all by the way,does the mip cvds ok with them?
Serum 03.04.2006 03:37 AM
MIP and UE cvd's are one of te few that work with the 1/8th diffs. So, that is a yes.. ;)
HotnCold 03.04.2006 07:09 AM
If your worried about twisting diffs and the such - might wanna consider the 8mm cvd's - plus they are a little longer - so no chance of the cvd popping out of the diff cup.. just my .02
luvsrc 03.04.2006 08:42 AM
where can i get info on 8mm cvd? thanks
Serum 03.04.2006 10:10 AM
Mike can get them for you.
Is it true H&C? are these 8mm's longer?
coolhandcountry 03.04.2006 12:33 PM
I don't think they are longer than the mip. They are alot better made and stronger though. My brother had a mip break on him and he didn't even jump it. He only had a puny 8L on it.
