And I did couple light runs to break-in differential. Quote:
I do not know, really. I do not even recall when that happens; just notice noise and erratic behavior of the front end. Maybe it was over hardened from manufacture or just a faulty ring gear. There is no a single scratch on pinion gear. Does anybody know where to get ring gear? Differential itself is in top condition. Artur |
Hello guys, and sorry to drag this from the bottom of the pile but I remembered this post well.
Looks like Novak has revised their KV rating of the HV-Maxx motor. http://teamnovak.com/products/brushl..._chart_web.gif 3100KV it is. |
They also revised the wattage of the motor. I think it used to be 375. Now its 500.
I wonder does this mean the older motor was closer to the 4.5 version. I wonder if the newer version has less problems than the older version.
My understanding is that the only difference between the 6.5 and the older motor is the nickel plated rotor. Windings are the same.
| All times are GMT -4. The time now is 03:48 PM. |
