Well here she is...now just need to do the electronics.
I added the Strapping Tape to the body to re-enforce the body and protect the paint at the points where it will rub.
Especially with these bodies...there is a lot of money in the body and paint...It's worth taking a little time to make it last for a while. I use Scotch Strapping Tape. http://i778.photobucket.com/albums/y...S/IMAG1058.jpg It is a highly tacky tape with a mesh weaved into it. This helps in the durability of the body to minimize cracking. http://i778.photobucket.com/albums/y...S/IMAG1059.jpg First place I put it is at the body mount holes. This is where a lot of the abuse to the paint and body is done. http://i778.photobucket.com/albums/y...S/IMAG1060.jpg Then it is time to find all the areas where the body may touch the chassis, tires, etc. On a SC Truck, the Front & Rear fenders get a lot of abuse due to the tires tucking up in them. Make sure that you protect the edges and flat spots on them. http://i778.photobucket.com/albums/y...S/IMAG1062.jpg Finally, I figure that this thing will end up Turtle'ing, so I added some protection on the roof. http://i778.photobucket.com/albums/y...S/IMAG1061.jpg |
Look what showed up today... and it is going to be 70 degrees tomorrow. :thumb:
http://i778.photobucket.com/albums/y...-18-53_444.jpg When you look close...what do you see??? Hmmmm, what does that mean? http://i778.photobucket.com/albums/y...-19-04_924.jpg |
So I got it installed...topped off them 8 Cells of Whoop Arse and plugged her in to take the test run.
Definitely running better. Did a couple laps around the neighborhood. Scared the sheat out of my neighbor cutting the grass. After a fast run down the street, heard grinding. Looks like the Pinion loosened up and ate the spur for Thanksgiving. http://i778.photobucket.com/albums/y...-09-31_945.jpg |
| All times are GMT -4. The time now is 04:29 PM. |
