-   -   Castle Creations Phoenix 110HV controller (https://www.rc-monster.com/forum/showthread.php?t=3797)
starscream 08.13.2006 05:27 PM
I just tested the HV again and it seems to run better after the software update. The throttle never reset but seemed to have a delay when letting off the throttle. I'll have to see if there are any config adjustments that may help.
squeeforever 08.13.2006 05:33 PM
Definately seems like a winner!
Serum 08.14.2006 01:22 AM
By looking at your screenshots;
Perhaps that's the .6 brake delay of the controller?
starscream 08.14.2006 01:46 AM
Thanks Serum,
That just may be the problem. The throttle lag isn't that long but at top speed, it doesn't take much to lose it :020:
I changed the settings to 100% brake stregth and "No Delay"
I'll see if I can test this out tomorrow.
captain harlock 08.14.2006 05:33 AM
Is there a specific link I have to use from CCs or do they only have one link?
I got one quite a while back.
Gundam-Guy 11.10.2006 03:07 PM
so is the Phoenix HV-110 runing fine now with the pistol grip this sounds like the perfect controler for my ride since i want to be able to do 24 cells and only need foward for it please let me know how its going
also can thishandle a 4pole motor?
starscream 11.10.2006 05:40 PM
I was very impressed with this controller but I could not get it to work 100% with a pistal grip tx so I eventually sold the esc.
If the MMM is anything like this controller, it will be worth the $$$
coolhandcountry 11.10.2006 05:54 PM
For 24 cells you can get the mgm 24160. It handle what you should want.
captain harlock 11.10.2006 05:57 PM
This dude is only 220 dollars. Quite a bargain for an incredible piece of technology. Mamba Monster Max is going to be some where near this thing.
The Mamba Monster Max is going to pull 200amps continuous as Joe had told me and 2000W+ surge, but the HV can pull an impressive something like 5000W.
starscream 11.10.2006 05:58 PM
The MGM would not work with the FMA LVC's so it was not a good solution for me. I ended up getting a Quark125B. It cogs just a tad on 6S but seems to work fine otherwise. The cogging only occurs when the motor is starting from a stopped position. If the motor is already rotating, it doesn't cog at all.
Serum 11.10.2006 06:02 PM
You didn't used the MGM's LVC?
coolhandcountry 11.10.2006 06:07 PM
Well he talking about 24 cells so the lvc is not necessary. Unless he changes to
8s later. The mgm has the built in lvc to. May not detect individual cells but
well work.
Serum 11.10.2006 06:11 PM
this was the reason why i mentioned it.
coolhandcountry 11.10.2006 06:16 PM
This is why i was talking about 24 cells and not needing a lvc.
Serum 11.10.2006 06:20 PM
You are probably one of the few people that even doesn't use one with his lipo's.... :p
