OK, I was under the impression it was a custom
BP - Spur/pinion ratio - 2.75 : 1
Final - 11.825 : 1 |
Based on your gear ratio's, I think a 16T pinion with a 48T-50T spur will be a good start for me.
Hopefully Mike can make me a 17T pinion...do any mods know the answer to that? |
He can not make odd number pinions above 15T He has never been able to find gear rod stock in those tooth counts. I asked a while back. Anything above 15T is only even tooth counts.
Aww...oh well. Thats fine I guess...I'll find the right gearing some how.
Does the 1950 (or and 19 series motor, for that matter) have pressed or screwed endbells? Please don't say pressed...
Pressed.
Ha ha, just kidding. I believe they are screwed and are quite solid. |
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (in an epic star wars style moan) :020: lol :005: Ok good...when I run with MetalMan he has at least 1 problem each time with the pressed endbell, so I didn't want to deal with that lol... |
Not each time... 7XL first time, and 9L third time :). This was of course after running many times with both motors prior to that :).
Front is screwed and is solid. Same goes for rear. The lehner isnt ever gonna come apart itself, thats for sure!
Yay! Screwed endbells woohoo!!! lol
Now mike just needs to get them in stock and Castle needs to produce the MM (or send me a beta one, even though I'm not a beta tester). |
I think you mean MMM* ;)
Yea, I meant MMM.
| All times are GMT -4. The time now is 05:52 PM. |
