-   -   MGM Programming problems (https://www.rc-monster.com/forum/showthread.php?t=7641)
david lamontagn 11.14.2007 04:13 PM
STOOOOOOOPPPPPPPPPP your horror history of MGM controler:surprised:
I'll suppose to recieve my 16018 tomorrow of friday, with the programing device, and i'am reading your smoking history with brend new MGM!!!!
I'll be very nervous to plug the batterie on mine.......
What happen with this $250.00++ controler??????
ope to not have any issue with mine.
Began to have somes regrets to not have take a Quark......
JPP 11.14.2007 04:38 PM
I understand the Quark has its own issues around cooling. As to the MGM, mine was repaired under warranty (although it took 6 weeks to get it back), and I view what happened as an aberration. The big problem as far as I'm concerned is the programming issue; I'm not the only one who has had issues with that.
Let us know how it goes.
david lamontagn 11.14.2007 08:01 PM
Why did you keep to use the Tx programming method:gasp:
The USB COM is suppose to simplify the programming task alot.
And for the price of this little programing device, don't know why lot of people keep to use the Tx for programming this controler.
JPP 11.14.2007 08:20 PM
I've since ordered the USBcom+ and will try it when I next get the chance, although I'm in essence having a problem simply pairing the device with my Tx. On a fundamental level, you have to get the ESC to recognize the end points of the Tx, no?
Humboldt8T 11.14.2007 09:55 PM
JPP - Where did you find the USBcom+? Mike seems to Out Of Stock.
JPP 11.14.2007 09:59 PM
Got it from Mike a couple of weeks ago. I just haven't hooked it up yet. Wife can't figure out why boxes keep coming to the house even though I haven't been in the hobby room for 2 months.
Humboldt8T 11.14.2007 10:18 PM
I guess I will have to wait for Mike to get his stock in.
Programming my MGM controller with my TX is a real hit-n-miss process. Sometimes it goes fine and other times it seems to go fine only to get the neverending beeps when I power up.
Delboy 11.14.2007 11:16 PM
MGM 16016 RB car setup solved.
Originally Posted by JPP (Post 129348)
Unfortunately I had to put everything RC away for the past 2 months due to my wedding/honeymoon and home renovations. Probably won't be able to break the stuff out again for another month or so, by which time Tekin should be close to rolling out their R1MT and Castle their MMM. Or I may just switch to a MM with a UBEC and fans, since I'm just using 4s.
Incidentally, what radio are you using? Is it a Nomadio product?
On this setup we are using the stock Losi radio, I run the React on my E-LST2 which has a Hydra 120 ESC.
Finally sorted the issue. The TMM16016 is a Z-Series 'RB' ESC (Race Boat) which is not actually what I ordered. Key difference is that it only has Forward (no reverse or brake) which is fine for the LST2 so it expects different end/mid points. By offsetting the Throttle on the TX I can program it as documented and it behaves fine.
I did order the USB (and may order the Black box as well) but it is out of stock here in Australia so am stuck with the 'hit and miss' TX programming at present.
Main concern is that I have the Lipo 4S setup correctly, if I read the instructions correctly I think the ESC still does a check on the number of cells connected and fails to start if there is a mismatch?
PS There is no BEC on this model which is also OK as we continue to use the RX Battery anyway as most of the ESC's we have access too do not support 4S for the BEC, this also keeps the ESC temperature down so we will continue to use the RX Battery.
david lamontagn 11.14.2007 11:32 PM
Tell me something, at the first time that we use the controler, how the controler will know the number of li-po cells connect to him????
They need power to turn on, and we don't have the choice to plug any batt to the controler to fire up and can go into the programation to setup the parameters...
So at the first time you use the controler, if he don't recognise the number of cell and fails to start, how can we program it????
Delboy 11.15.2007 01:59 AM
The ESC can approximate the number of cells based on the voltage. I guess initally it checks the voltage, sets itself up accordingly so you can program it. Once it knows whether you are using NiMh or Lipo it can work out the number of cells fairly easily.
Just my guess........
Finnster 11.15.2007 11:53 AM
The controller defaults to Nimh mode, so there is no voltage cutoff.
Are we sure that the controller won't even turn on if there is low voltage, or just not arm? If you messed up the cell count, ie put 6 instead of 4, don't have a 6cell lipo, it doesn't seem right that this would just brick the esc until you could get a HV pack. I could see it let you do the programming, but not arm, but haven't tried it so don't know for sure.
david lamontagn 11.15.2007 04:34 PM
Just recieve my 16018, program Futaba FASST Tx end point, all is OK to date. Rest to program it with the USBCOM+ tonight.
Very impressive controler, it's big and heavy compared to a MM:oh:
lutach 11.15.2007 05:33 PM
To be honest, I don't think he MM even comes close to the 16018. I have the TMM 8012 that runs cooler and better then my MM ever did with the Noval HV4.5 motor.
