Thanks for the reply BrianG
Mine is kyosho MP7.5, is it ok if my motor feigao 8xl (2084kv) with 4s 5000mah lipo & will the Quark thermalled? My gearing 14/46
With the internal mod and added heatsink (Mike has one in the store specifically for the Quark), it shouldn't thermal. I've never thermalled my Hyper 8 with the same voltage, a 2700 kv motor, and geared 46/16.
what is the hottest temp of your quark on your setup 2700kv? my quark is 106^C(224F) & motor 6xl (2770kv) on 4s lipo
instead of using thermal epoxy, can i use aluminium putty to stick the heatsink to the FETs?
pullinteef: I run until the battery dies, which is around 35 minutes for an 8Ah pack. This is my setup so you can see how things are mounted. Temps are never any higher than 150*F on anything. I've since geared down because ~55mph on a track is a little tough to control.
streetracer: I'd stick (no pun intended) to thermal epoxy. I don't know how well the putty transfers heat, and if it is conductive (you don't want this). |
Hey BrianG, could you let me know the settings on your 125b? Specifically the Battery Type/Torque control/Drag Brake. Or anything else that might effect ESC/motor temps. Thanks.
I think these are the settings I use:
- Default brake strength (normal) - Default drag brake (second option up from 3%) - Battery type is "manual" - Battery LVC is set to 3.0v/cell - Torque Selection is Normal 1. - Neutral range is narrow (makes for a more gradual/smooth start) |
Thanks. I've been having a hard time keeping temps down on both ESC and motor. My 1512/2D/S died last weekend- not sure if it demagnetized from heat or something else (just stopped after a big jump about 8 minutes into the main, and felt really weird when turning the shaft), so I'm forced to temporarily use my 3 year old 540C-9L motor while the motor gets repaired by Neu. Don't know if it will hold up to 15 minute mains.
That is odd. I've never had troubles with either Quark or Neu temps. On my old Quark/9XL Revo, the motor would get kinda toasty after around 15 minutes (when the batts die), but still way under the danger zone, and that was a cheapie Feigao.
Without going through above posts, what batteries are you using? |
Using new Zippy-H 4S 5000, (work great, stay nicely balanced)
RC8, 12/46, drivetrain free, big track, big jumps, but I don't use brakes much (seem to lock the wheels even on low setting) and try to avoid gassing or braking on landings. |
hello!
im kim in japan. I am interested. Is this condenser usable? Is it LOW ESR? 35v 1,500μF 0.014ΩMAX. 105 degrees Celsius, http://www.edc.sanyo.com/pdf/alm/J60.pdf I want to use you as MGM 16018. How? |
It is how many and is all right if usable?
I want to use 2 or 3. |
| All times are GMT -4. The time now is 02:26 AM. |
