-   -   Mamba Max above 3S LiPo (https://www.rc-monster.com/forum/showthread.php?t=9383)
GriffinRU 01.12.2008 06:54 PM
Originally Posted by suicideneil (Post 140687)
Hang about, you did just say that all the MM escs work upto 6s/25v, if you switch off the lipo cutoff (and use a seperate LVC I presume)? Interesting, verrryyyy interesting....
All, the ones which I have...starting from gen1 up to the latest. I have brains from various generations, so I built a simple fixture and tried them all.
No separate LVC, just bench testing with load and receiver pack.
DrKnow65 01.12.2008 07:04 PM
Thank you Artur, did someone provide a gen3 for you to test?
suicideneil 01.12.2008 07:22 PM
Sweet. Assuming it all still works fine once the brain is reconnected to the/a powerboard, you would need to use a seperate LVC to protect your lipos (since the built-in one is turned off)? That was what I was getting at before really. You never cease to amaze me with your electrical wizardry.... :intello:
GriffinRU 01.12.2008 07:22 PM
Gen3 the one with 30 Fet's, correct?
DrKnow65 01.12.2008 07:23 PM
Yes, the newest version. Are there more than 3 generations, or less?
GriffinRU 01.12.2008 07:37 PM
I've seen 4 variations so far...
<TABLE class=tborder style="BORDER-TOP-WIDTH: 0px" cellSpacing=1 cellPadding=6 width="100%" align=center border=0><TBODY><TR title="Post 140701" vAlign=top><TD class=alt1 align=left>suicideneil</TD></TR><TR><TD class=alt2 align=left>Sweet. Assuming it all still works fine once the brain is reconnected to the/a powerboard, you would need to use a seperate LVC to protect your lipos (since the built-in one is turned off)? That was what I was getting at before really. You never cease to amaze me with your electrical wizardry.... :intello:</TD></TR></TBODY></TABLE>
I've tested 2 modified controllers with 6S for 30 minutes, running up/down/brakes with no problems. Have not tested unmoded ones.
ilpufxit 01.12.2008 08:22 PM
MM mods
I just sent one of my MM esc's in for mods. I'm hoping to run 5s in a 1/8 buggy when I get it back. Does that seem realistic? Reliable? I'm running it now on 4s with an un-modded MM and so far no problems. I was running an 18t pinion and it got pretty warm after 8-10 min really heavy bashing, didn't thermal though. I switched to 14t and there's very little heat.
DrKnow65 01.12.2008 08:24 PM
What motor are you running?
ilpufxit 01.12.2008 08:36 PM
Motor
Its a Feigao 8xl. Around 30kv if I'm not mistaken.
GriffinRU 01.12.2008 08:43 PM
8XL (kv2084) at 5S would be too hot...
Thunderbruiser 01.12.2008 11:55 PM
hey griff i want to look into mods for my mm what does the stg II include? please pm me with details thanks
GriffinRU 01.13.2008 01:38 AM
Mod2 requires two ESC's and as result doubles number of Fets. More Fet's - more Amps.
