-   -   Tekno RC Neu or Orig Neu (https://www.rc-monster.com/forum/showthread.php?t=12705)
FunkedOut 06.13.2008 08:54 AM
those joints get real hot on my 3905. it's got to be from all the friction when they rotate.
Mozzy 06.14.2008 01:19 AM
Originally Posted by MacII (Post 181639)
I think that's WAY overkill. I've got a CRT running 4s on a 2200kv and it's ballistically fast. Too much speed and power for the track - big track too. Can't imagine how unholy the speed of a 2700kv on 5s will be...you can't gear low enough...
You think so?
I didn't think it was fast enough on 4S & the runtime was way down to what I expected.
For example, I used the 3800 & only got 5.30mins out of it & the 6000 was only 11mins.
I want 5S so I can reduce the power draw with my Tx & increase runtime.
Here's our track, which has only just been finished to race on, but, by no means is the whole area finished.
Still need a drivers stand & it's been put on hold due to Federal Legislation stating that it needs to follow specific guidlines to meet disabled access requirements. So the guy's are working on a design to make it a cheap easy build.
http://rcmadhouse.com/MadForum/viewt...?p=22444#22444
Electric Dave 06.14.2008 07:39 AM
Wow, serious track. I've only had my 1515/1y for one practice and one race weekend. That weekend on a very small and easy track it was drinking about 1800mAh from my 4900 packs to complete a 5 minute race. Not bad considering the motor I replaced was doing the same thing in 2600mAh plus it was WAY faster.
How are you gearing it? I've got mine pegged at 38.75/36.8 according to BG's speedcalc. On the track it feels much faster than the numbers sound. Even at Wolcott, which is a huge track (like yours) it was plenty fast with plenty of go to clear the biggest Quadruple jump I've ever hit.
George16 06.14.2008 07:40 AM
That's a nice track you got there!!!!!
Mozzy 06.14.2008 07:56 AM
There are nitro guy's lapping at around the 45sec mark.
I'm running stock gearing on my CRT, so, whatever that is ratio wise(??). Basically 13/62-63. I can't remember the stock CRT gearing.
One of the guy's just made all the pics into a panoramic shot.
http://idisk.mac.com/jensrudnick-Pub...RRCC_Track.jpg
cemetery gates 06.15.2008 12:22 PM
Originally Posted by Mozzy (Post 182010)
You think so?
I have a Jammin CRT with a 1515 1/y that I run on 4s 8000mAh packs and have almost the same results as you. I geared it 14/62 and pulled 1700mAh in 5min. at the Barn.
Mozzy, I think something might be wrong with your setup if your using 3800mAh in 5.30min. And yes, I have more power than I could ever need at the track.
Bye:mdr:
Mozzy 06.15.2008 09:30 PM
I just wish I knew!
Should I change to a 14t pinion & see if it makes a diff?
Dammit! I want this thing to run longer than it did as a nitro. I'm sure I'll get there eventually.
