and yes there is a gap but i stayed as close to the front center as i could
http://i38.tinypic.com/160re44.jpg |
That is close. A good crash might take that into the spur, and that steel gear could get through the tray and rip the lipo faster than you think.That would be bad. I had 2 screws tear out of mine after landing upside down and backwards, looped out on a jump, snapped wing mounts and a loose battery tray.I would try to get a little more room or get a 42t gear. That reciever tray is another lipo damage point.Better safe than sorry IMO. Looks good otherwise.
i have a mm and a half and its servo taped screwed and strapped so its not moving all four screws are tapped in.
btw, looks sick. now I REALLY need to get my lsp back together haha. |
well here it is 90 percent done just need new front shocks and springs all around, still waiting on center speed control mount. cant wait to take it for a spin
http://i37.tinypic.com/2ajdqgg.jpg |
You will like it. I broke mine friday. About 20 out and landed bad. Boke the wing mounts and a rear hinge pin holder. Ordered some Kingheadz hinge pin holders. That may just cost me some a arms though. Just make sure the center diff oil is right. I use 30k and it seems good. Brushless needs a little thicker than nitro due to the instant tork they have.If it is to thin you will beat the front tires up quickly. Tell me how you like that battery after you run it. I'm running NeuEnergy 2s 4900s in series. 4s. I got the 2s so I can use them in my E Maxx and 3Ts but am thinking of getting some 4s packs.
i ran it today and its great. absolutely flies but needs heavier oil in the center as the fronts are doing too much work and its hard to even get the front end off the ground for long. didnt even get through a full battery before the pinion spun off and i coudnt find it so i will have to order another pinion before i can run more. ad yes it had locktite but i guess not enough. but it has lots of bottom end and is at least 50+ ran for about 15min and never got hot at all was running suprizingly cool.
Sweet. I just got another center diff and am going to try 50k oil in it. I'm using hyper st spider center diffs. they have 52t gears on them. They are quieter than the 62t (not sure why, still a steel gear) and give more clearence.http://cgi.ebay.com/OFNA-Ho-Bao-Hype...3A1%7C294%3A50
hmm i just blew my fron diff today i need stronger internals will the hotbodies hardened kit fit on my crossbars in my stock diffs?
never mind after syarting to take it apart i realized it was just the set screw on the front drive shaft, a much easier fix,lol
project complete runs great no complains runs cool even beating on it so far and more than happy with the speed geared 62-14 for around 57mph just need the snow to go away so i can stop running it on the road and wearinf out the tires faster than i thought possible. so thanks everyone and and any further tips would love to hear still have new x2 big bores with springs on order but im still running the crap shocks on the front and my make shift springs on the rear till i get the right stuff next week.
http://i37.tinypic.com/33c52kh.jpg http://i38.tinypic.com/25hmmnm.jpg |
Only advice i have is gear down.. :lol:
well i dont think i will be doing that,lol, i love speed and dont always use it but its nice to have on reserve plus my temps are great. coolest running setup ive ever had motor is only warm to touch as of yet. plus if i wanted a slow truck i would have stayed with nitro!
:lol:
| All times are GMT -4. The time now is 10:29 AM. |
