I got the axles on and the shafts in and everything is pretty much good to go...
Well I just rolled it around a little and moved the wheels with my hand, and there is a TON of resistance. I know its coming from the diffs, but not from the gears. I think its from the green goo thats on the diff casing and on the big bevel gear. The little pinion gear now has all the goo on it too and its really thick, so I think thats creating the resistance. Im hoping that after the first time its run the goo will get flung around and will barely be on the gears letting it move alot more freely. Does anyone else have this problem? Does it go away after the first run? __________________ |
Could be a case of over tightened diff housings (If you are using plastic gear housings). Try loosing each screw for half a turn. |
Thanks littlegiant Ill check it out.
Just to make sure, the buggy/truggy pinions are usually Mod1 48p right? Im having a hard time finding a pinion like that under 10 bucks.... :confused: More pics... http://i181.photobucket.com/albums/x...unny/full1.jpg http://i181.photobucket.com/albums/x...unny/full2.jpg |
You need to use MOD1 pinions, no 48p or other p!!!!!!!!!!
Greetz, Joram |
Well i went back to the senior design workshop and found the perfect sheet of aluminum for an esc plate. The holes are EXACTLY the right size for an M4 screw and were in the EXACTLY perfect spot to line up with the holes already in the chassis for the GP motor mount braces. So I snipped it up to size and here is what I have for an esc mount now. Notice it leaves just enough space for the motor to clear the top of it. Man I lucked out on this one!
http://i181.photobucket.com/albums/x...y/escplate.jpg http://i181.photobucket.com/albums/x.../escplate2.jpg http://i181.photobucket.com/albums/x.../escplate3.jpg |
Looks like a fun build joey. Make sure you get the pinion perfectly meshed with the CD/spur. Seems as of the motor is tilted towards the mount making the pinion set lopsided onto the cd/spur. If you ruin it this way it could give you issues with heat and excessive wear.
Hahaha LG Im wishing I could have something new to update! For now Im deadlocked into studying day in and day out... no time for fun.
I have 3 packages in the mail... Bearings for the servo saver to replace the 4 bushings, hinge pins for the lower axle to arm joint, and duratrax warhead towers. The shock towers on the savx are too high for my liking, and I already have some warhead shocks (about 128mm) so Im going to try to hack up the X tower and mount in the warhead tower for some low riding goodness. Updates when I can... video... not for a while ;) Oh and I balanced my wheels. They were WAY out of balance. I used small strips of duct tape on the inside of the rim and it worked great. Took the dogbones out and used the free spinning axle to balance, worked well. They are about 90% balanced now, definitely good enough but I may try to get it perfect sometime... just hard without a high quality balancing shaft thingy. |
The wh towers are nice. Alot of shock adjustment options.
Seems like its gonna be more work than I thought to make those warhead towers work. Ill see what I can do when I find time.
Just put my short shocks on the savage with the stock towers, obviously the droop is completely gone but I did it just just so see how it rolls. Well........ There is a HUGE amount of noise coming from the diffs, sounds like they need to be shimmed bad, but I didnt think savage diffs had that problem in stock form. Whats going on?!?!?!?! |
Update with pics
Update with pics
Great truck! I have a couple questions for you. How much have you spend to date? Would you mind making me a list of the parts you bought? Thanks very much!
Suspension arms: --------------------Bought for $13 shipped.
Bulkheads + Diffs + Shock Towers: -- -Bought front and rear for $47.20 shipped. Bumper + Skid assembly: -------------Bought front and rear for $8 shipped. X TVPs: -----------------------------Bought for $15 shipped. Axle dogbones + cups: ---------------Bought for $25 shipped. Center diff/tranny and mount: --- ----Bought for $27 shipped. Bellcrank/Servo Saver assembly: -----Bought for $6.50 shipped. Axle carriers + bearings: -------------Bought for $13 shipped. Suspension arm hinge pins: ----------Bought front and rear for $4 shipped. Screw set + misc: -------------------Bought for $12 shipped. F/R Turnbuckles: --------------------Bought for $6.70 shipped. Radio box: --------------------------Bought for $8 shipped. Center dogbones: -------------------Bought for $15 shipped. Chassis braces: ---------------------Bought for $10 shipped. Extra screws/hardware: -------------Bought for $8. 17mm hex hub set: -----------------Bought for $10 shipped. warhead towers + shock mount kit -- Bought for $15 shipped Total cost so far... ----------------- $235 I already had the shocks, wheels, and servo. Hope this helps! |
| All times are GMT -4. The time now is 11:50 PM. |
