| _paralyzed_ |
10.31.2010 10:55 PM |
Originally Posted by ZippyBasher
(Post 385863)
I Realize you work for CC but I still think the motor will handle the 3s in a rustler or 2wd slash just fine. Considering the weak 2 pole VXL motor pushes my Full Aluminum Rustler with masher 2k's. Maybe the Speedo will run a bit warm but I dont see the motor needing cool down every 5 minutes
Whoa dude, btfu. Do you understand how much of a privilege it is to have the OWNER and CHIEF ENGINEER of Castle Creation Inc. comment on our forums? Please do not argue with anybody from Castle. Their word is gospel. All we ask is that you listen to their word as you would the word of God. Thank you. Seriously. Respect man.
Originally Posted by Unsullied_Spy
(Post 385906)
So the 1406 on 3s in a Rustler is a bad idea? I know my 1506 is a bit larger and likely more powerful but it motivates my Rustler with serious authority geared 15/56 and doesn't even hint at getting warm on 2s with ESC temps reaching as high as 110 degrees (GASP!). Running 3s my motor gets up to 160ish in the Summer and if I am really pushing it I can possibly thermal my MM but only after running the crap out of it for a good 30-40 minutes--if I stick to 1 battery or give it a short break between batteries I can run through 2 packs without heat issues. With the blower on the 1406 and being run somewhat intelligently I'd think it would be OK.
It's a liability thing. They CANT say it's 3s capable, or they're liable for all 3s applications. Between you and I and the RCM family, yes, it is 3s capable. As far as Castle is concermed it is only 2s capable.
Originally Posted by phatmonk
(Post 385945)
How are these 1410 motors compared to the say 1515 efficiency wise.
This motor is not anywhere near a 1515 powerwise and should not be considered for a 1515 replacement or alternative. That being said, all castle and neu motors are 90+% efficient and efficiency wise is quite comparitive or similar.
