Heck, you might be fine running 16 cells - I personally wouldn't for the reason stated above. I like to keep my best-case (meaning highest possible voltage off the charger) voltage at least 25% lower than the component max ratings. That puts it to ~19v max if the caps can be used as a guage. Who know what the other components are rated for...
Interesting thing with the caps, Brian - the 18 cell Shulze controllers use 25.4v caps as well. In fact, most controllers aside from BK that are rated for under 20 cells use the 25.4v caps from what I have seen. BK uses 50volt caps for reference. All things being equal, I would suspect lower temps with higher voltage when geared for the same speed. And I always use a fan - cheap insurance IMO, though I agree that if a fan is NEEDED, then the setup needs work. :)
You have great products, I own three Mamba25\Max controllers. Keep up the good work :027: and leave my fan alone:018: :018: |
btw, any pics of that track??? |
http://www.rc-monster.com/forum/atta...2&d=1151156718 |
I dont run fans, I think some do more harm than good. I will try mine on a 15 minute race and see how hot it gets on 5s. Keep in mind, I dont have it geared totally stupid, geared for 37mph top speed...barely hit that on my local track. Running the Nomadio to monitor temps and voltage, so far so good. Love the Mambamaxx......
| All times are GMT -4. The time now is 10:57 PM. |
