The stall current thing is a 1/X relationship current vrs RPM -- non linear with RPM. So at stall, current is infinite (limited by motor phase resistance -- not much of a limitation.) |
Think about a brushless motor as a stepper motor with magnets and a synchronous controller. :) |
Yeah, I understand that, but I figured since there are so many more phases to get more samples from, slow running would be smoother. In effect, a hundred-phase BL motor.
In a regular 3-phase BL motor, you have to get so many revs before you can get a good reading on actual rotation, so slow/stall conditions are harder to deal with. Just throwing ideas out, sometimes it's nice to think outside the norm... |
It doesn't matter, you do not like sensors, it is alright. You have interesting opinion about optics. |
I have done some research on stepper type motors for crawling, and the main issue is the resistance of the phases (in effort to prevent ridiculous amp draw) and that the ESC would have to be matched to the motor in terms of PWM so that the coils didn't blow under load.
It would be much simpler to just throw a sensor on an outrunner to bump up the starting torque and zero rpm sync, then switch to sensorless at around 500 to 1000 rpm depending on motor. Some over current protection might be a good idea. |
GriffinRU: can it be done? (brain transplant) |
The trick is at fet's drivers not in fets. While they do have nice layout, CC's board is also nice. But there is a small difference which is clear on the board and inside firmware as well. I think if Patrick will do the same, he might get similar performance with current firmware. But, Frankenstein, in this case would be very complicated. New MGM's I think have the same fet as CC, if you check old 160Amps ESC had 4 boards now 160Amps has 3 while 224Amps has 4... |
I guess I will have to install the MGM in my truck this weekend (just got it back with 3.23 firmware), since it looks like I will have to wait a while on the MMM sent in for replacement. Maybe the new firmware on the MGM will allow me to run reverse without all the quirks (crosses fingers). Castle IS by far better on the software side, I run reverse on the mm's (as well as the MMM for the whole 5 min I got to run it) and never worry about it, until I need it, it just all works like it should. I have had all kinds of wierd things go on with the MGM at one time or another. One nice thing on the MGM is the ability to read out the max temp (internal) and the amps (hint, hint Patrick).
I have the new software and run it with the medusa with none of the reverse quirks that it had running the 600xl. The medusa's being four pole should be quite similar to the neu in behavior I would think.
I've had great success with my MGM controller and the updated firmware. I run a Neu 1512.
Some kind of telemetry feature, even a basic one, would be nice on the MMM- download the info via castle link to your PC or laptop. Temp, current draw, motor rpms would be awesome- even if it had to be a little add-on box or something that plugged into the main PCB, like the fan does or something.
Intelligent Q now: With regards to the fan issue, can I get a definative answer as to what Castles take is on case-modding the MMM? I would like to do something like BrianG has done and turn the esc into a convertible, but use my own larger (more robust :whistle:) 40mm fan to improve cooling, but I dont want to void my warrenty (modified case can be re-used even if the PCB went poof a bit...). I like to think of it this way; a heatsink on an esc only works with good airflow, and to get good airflow the esc needs to be posistioned like so. Unfortunately, this isnt always possible, so a fan is therefore used to provide artificial airflow, replacing the natural airflow that would be present as the vehicle moves along at speed (certain chassis and shell designs prohibit airflow). I dont believe a fan should be used as a forced-cooling device like a desk fan pointed in your face, that does imply that that the esc runs too hot under normal conditions. Replacing lost or unavailable natural airflow with a small fan is perfectly acceptable in my view. Plus, fans look cool.... |
guess I better get busy and get the thing installed.:whip: |
So the new version of the firmware is working good then. Is any of you guys with the new firmware experiencing acceleration when braking? what about no braking at all when it doesn't accelerate?
I ran mine for a few this morning, seems like a new controller. I will post more results in an appropriate thread this evening after more running. Sorry for the highjack.
A question for the engineers out there :lol:. Would it make sense to have a lot of MOSFET (Lets say a FET driver already was chosen and powerful enough to drive close to 300 FETs) on a controller to make each MOSFET work less to provide the power some of us need? Lets say I have a design for a controller with 240 MOSFET total, 80 per board, would it actually run cooler because there will be less load for each MOSFET? The reason for this is I see a few controllers with less FET that actually run a bit hot, but a controller with the same spec (AMP rating wise) with more FETs will actually run cooler. One example is one of my 30A old Kontronik controller runs cooler then some of the latest 35A controllers.
Well, I would think that the more surface area you have to dissipate a set amount of wattage, the better. More FETs translates into more surface area to handle the same wattage (heat we need to dissipate). But with that said...
The only thing I would be conecerned with is if there would be some sort of inefficiency with driving that many FETs? I mean, each FET is only efficient to a certain point, and what about switching losses? More FETs means more wattage lost due to switching loss no? Interesting problem posed lutach. I'm going to keep an eye on this thread to see what the general concesus is from Patrick and Artur (and anyone else who's an EE- which I am not). |
2 Attachment(s)
1 Attachment(s)
More fet's bigger foot print more surface area to dissipate heat, more overall losses... Fet's driver need to be very nice or need to be on each FET's board, but try to sync them...possible. Let's do quick theoretical calc, if you can drive fet's as fast as fet can switch (non-real) then 300 fet's you meant total, so 50 fet's per leg/100 fet's per phase. Dynamic losses would be ~10W on fet and ~10W on diode, check attached image. With 3 phases your loss would be ~60W just for switching at 15kHz PWM, that would cook ESC pretty fast without proper heatsinking, by the way can be a nice heater :) It would be nice to keep dynamic losses matched to pcb heat dissipation capacity. I am pretty sure, Patrick can add/correct my post if required. |
What I was getting at is basically looking at the Tekin R1 controllers. They are small and pack a lot of FET for the space so if we were to make them a little bigger and add more FETs, would that make the FETs work less to produce the same power and thus having less or the same amount of heat? I own a Etti 200A controller and I ran it a few times. This controller is only rated for 5S lipos and I ran 5S on it and the controller didn't even get warm. This controller doesn't have a heat sink like most car controllers and I was surprised on how cool it was. My set up at the time only pulled 98A spikes, but I ran my truggy for 7 minutes. The one picture in my previous post shows a 6 power board controller that puts out a lot of AMPs. Something like that would be great for the surface side of the hobby. |
There are alot of fets on those escs, but it isnt anywhere near 300- I would assume there is there is some nice graph somewhere that would show the maximum number of fets you could use (of any size/voltage/current rating) before they did more harm than good...
I agree with using more fets though to lower temps/work load- makes perfect sense. |
From 50 fet's (300 total) to 8 fet's (48 total, Tekin R1PRO) your dynamic losses falling from ~20W to 3.2W, pcb can absorb that. Conduction loss at 100Amps @25C with 8 fet's ~2W -> as you can see great combo. Dynamic losses are small with less fet's and becoming dominant with more, so balance should be found in-between on design stage. Where entire ESC been layout and verified step-by-step, you just cannot add fet's boards without penalty. |
Artur,
I sent you the e-mail with the 2 photos. Let me (us) know what you think of those controllers. |
Dynamic loss is fixed with fet, each fet has a capacitance in the gate (value dependant on temp, load...) to charge and discharge this capacitor requires energy, so more fet's more energy. Conduction loss would be related to Rdon and more fet's lower value, so good thing, but as you can see you need to keep balance... I will check e-mail later, and let you know. Keep in mind TO-220's and D-Pak's are huge packages and can easily absorb ~1W without heatsink, but they are not as fast as smaller, tuned fet's. Your Amp has a pretty sized heatsink, right :) |
The LFPAK package is much smaller than the D2PAK, occupying the same pc board footprint as the familiar SO-8 package. However, unlike the SO-8, the LFPAK is a true power package that incorporates a bottom metal contact, which provides an effective heat path out of the device. There is an additional thermal pathway between the top of the device silicon and ambient through the top part of the encapsulation. Although the LFPAK solution increases the total number of power packages used, the total board area occupied by this solution is significantly less than for the D2PAK case because the LFPAK package is much smaller than the D2PAK." and "In the last few years, there have been significant advances in the packaging of MOSFETs, including the introduction of the power SO-8 package. Bottom-side cooling can now be used successfully to transfer heat through the pc board, even when smaller power packages like the LFPAK are used in place of the D2PAK. The package on-resistance and inductances for these smaller package types are also significantly lower. The total losses in a system caused by these sources are therefore reduced significantly, even with the additional devices needed when using the smaller package types in place of larger MOSFETS. The greatest advantage when switching from D2PAK to LFPAK is the resulting reduction of board space occupied by the MOSFETs, since pc board top copper is not needed to radiate heat. The smaller MOSFETs can be placed closer together, and the previously occupied board space is made available for other components." The components that I have in mind though are much smaller measuring 3mm Length x 2mm Width X 0.8mm height. If this works, it should make a very powerful controller. |
Lutach- sounds like you got some serious stuff planned. I haven't read through all of your posts yet, so I'm a bit behind. It's nice to have consumer ideas thrown into the mix though! So what's the difference between the SO8 FETs and the DPAKs? I'm guessing DPAKs have a metal type housing whereas SO8s are still that resin/plastic? |
The DPAK doesn't take as large a die as either the LFPAK or the SO8-FL, and it has about 2 milliohms of package resistance -- making it not very well suited for 30V applications. |
Now for my other question I posted before. Being able to drive all the MOSFETs (keep this in mind), would a controller with 240 MOSFETs total or 80 per phase, but 40 in the H bridge config. work less to make the same amount of power as one with less MOSFETs? Now, this controller don't need to be all that small. Something that is smaller then the Schulze 40.160 will do :lol:. I know more FETs and other components will add to the cost, but that's only if parts are being bought from Digi Key, Mouser and any other catalog distributors so lets keep that on the side for now. I'm just trying to get a rock solid controller. I even went as far as contacting and sending 1500 MOSFETs to a company in China to make me a 15S car controller and they never did one so you know the problems they are facing. All they make is Airplane and Helicopter controllers. I know they are using the Atmel's ATMEGA8L-16AU MCU and some car controllers that I have uses the same MCU. My guess is they are still having trouble with the software. |
So it's unlikely that they have any resources to modify the software for RC car use. It's funny, most of the controller coming out of China identify themselves as a Jeti-18 (regardless of the type/size of the controller) when connected to Jeti's field programmer. Several others ID themselves as Schultze. I've yet to see a Chinese or Taiwanese controller that has decent software that was not stolen from another company. |
| All times are GMT -4. The time now is 03:29 AM. |
