Wow.... 117°... could you post your setup and some photos of your machine? |
I will post setup/pics tomorrow. I'm just in the middle of cleaning the truck up from a good day yesterday :) |
castle told me that the motor was good as long as you kept it below 200!!! but i will stick to max 180!
@scarlett.... i have used the HD gears 2 times now and both sets have stripped on me in around 12 runs or so! Its cheaper to use stock ones and change them every 6-10 runs and they have better contact surface area. Just works out better for me till i do the CD conversion. @rolr... get some pics up of this xxl lst... Im sure my savage would love to run all over it :na: your geared for 45 im geared for 53mph :rofl: lol jk. But seriously what is your lst weighing in at? just want to compare how these trucks weigh compared to their gearing etc... and what temps they are producing. |
http://www.vimeo.com/12832488
The motor is in the purp MBX5T truggy ;) You can see some air at the end, and how easy the motor works to push it in 3-4meters altough the high punch control at 70% ! |
Look... It's a Bird...It's a Plane... it's SuperMBX5T:lol:... damn that thing can fly... nice vid man... keep them coming...
Alien |
Nice vid man.
Sorry for the late response. Here are some pictures of my bashing beast.
-LST2 -XXL Chassis conversion -MMM/1520 motor -Flextek Titanium arms -Aluminum hubs -Tini Pinion/Spur/diff gears/tranny gear -Forward only conversion, E-LST gear swap -I made a make-shift battery tray out of an old parts container while my new one was being shipped, however I continue to use it as it does the trick quite well. I absolutely love the weight setup of the truck... As much weight forward as possible, and it still jumps level! Don't mind the crappy pictures or state of the truck, just waiting on some parts to beef up the corners a bit more. http://img251.imageshack.us/img251/2820/img0326rw.jpg http://img819.imageshack.us/img819/3707/img0328sz.jpg http://img822.imageshack.us/img822/2237/img0327y.jpg http://img413.imageshack.us/img413/1482/img0329i.jpg |
i love those arms!!! look so good! YOUR LST IS HAUGGEEE
117°C is 242°F. Castle motors must be kept below 200°F or 93°C.
My motor stays cool in my Savage on 6S with 20/44. Still flips too easy though. Need to swap all the stuff to the Muggy now, the center diff should be great for handling. |
Yeah, figured it later since the other guys would think it's still really cold in Canada. :lol: (or is it?)
Check the mugen spur and the rear shaft ;) Shimming was always correct :lol::lol:
http://img251.imageshack.us/img251/3719/54704027.jpg http://img228.imageshack.us/img228/7947/74324378.jpg |
Interesting... what make pinion are you using? I don't normally see that kind of deterioration on spurs...
Alien |
Many ^^
RCmonster pinions : eated after 5-10 bateries :( Robinson racing : eated... losi : eated.. ect.. ect.. novak : seems to be no digestive for the moment :lol::lol: |
I feel silly for asking, but that's not the gear mesh you normally run, right?
As the spur use itself with time, I thought that I had to move the pinion closer to the spur, but with this method I used my pinions pretty quickly... So now I decide to stick with the original shimming when the spur was new, and it seems to work, my pinions and spur dont use themselves anymore. At least for the moment...
I run with the mesh you see in the photo :whistle: |
hmmm.... just curious... how did you determine the distance between the spur and pinion?
I have some plastic piece between motor and chassis reinforcement, which keep the motor to move latteraly, and it give me information on the shimming too.
And I can feel it with the play between pinion and spur when I move the spur up and down. |
zeen... I get a little confused myself when meshing metal gears... with plastic spurs and metal pinions i used the 'Paper Method'... running a sheet of paper
between the gears to achieve a relatively good mesh... But I'm sure if that method can be used with metal gears... |
Some people do that with metal ;)
But I prefer the hearing method, I hear carefully the noise that my mesh is doing to adjust precisely the shimming. I use my eyes too, with habit you can see a proper or bad mesh, and the noise confirm it ! |
I make sure I can feel alittle bit of play, rocking the spur back and forth I can hear, feel, and see the perfect mesh. Its just a small amount of click/clack. The paper method got me prepaired for this.
Cool... I use the by ear method also :lol:... I am really interested in those Novak pinions though... maybe I'll give them a try soon.
i have never seen wear like that! Your pinion is handling it very well!!!! Thats usually how my pinion looks as my spur is still fresh! Got to try novak next!
Lool no no no, the pinion is brand new, the spur has already seens a lot of 80 batteries of 6S 4000mAh and a lot of nitro liters :D, I bought the truggy used !
woah thats one long lasting spur!
No because when I said it's new, I said it have a few batteries, some other brands pinions were very used only after one or two batteries, that's why novak seems to be the strongest pinions for the moment.
Anyway I will post new pictures of the mesh in a few days, as I drive my truggy one or two hours a day, it will be revelative ;) |
I see... well post your findings when you have them... I am tired of killing pinions now... i need to find a set that will hold up to the punishment the CC 1520 dishes out...
Your spur is holding for now ?
Well the spur is fairly new... not many runs on it... no signs of wear yet. I have an older RCM 18 tooth pinion mounted now and it seems to be doing much better than the newer ones..
ive decided to try an HPI Pinion again. It seemed to hold up before on my other motor and it was rarely changed... Lets see if it can handle the 1520!
Mine unscrewed once and got shreaded like butter lol. (2200 4S)
Yeah my RCM pinions(all older) did great. All my Novak ones have been great as well.
Ok my result of an HPI Pinion
I met up with a few people to bash the trucks. I put on a brand new 17t HPI pinion. I ran two sets of lipos through it yesterday... I ran one set on grass and one set on dirt doing jumps. Today i ran twice. So two sets of lipos. But before i was halfway through my secondset today, i could hear a wierd noise as if the gears were not meshed correctly... This was the case but because of extreme wear to the pinion. It shredded after 4 sets of lipos!!!!!!!!!!! This is terrible!!!!! I think i am going to have to start using a plastic spur! I can not continue to change pinions every 5 runs. It is so much effort ripping the truck apart ever 3 days!!!! I just do not have the time! The truck runs absolutely amazing, tearing the grass up wherever... But its taking its toll on the gears. WHAT SHOULD I DO? Novak pinion and a plastic spur? |
You definitly should try the punch control. Try it just for a few pack at 60-70%, maybe it will be OK for you, and it definitly would increase your pinions life ;)
Before changing the spur, try NOVAK pinion, with plastic spur you will break the spur every set of lipo :( |
Ok... i will try that guy from HK Selling packs of 3 pinions...
BUT I WILL NOT LOWER MY PUNCH!!! i love having the immediate power! I still think a plastic delrin spur is what i need though! |
I think you have to look at the people who are not having these problems. What are they doing that you are not?
Most of the people have not a 17lbs truck geared for 50mph :lol::lol::lol:
| All times are GMT -4. The time now is 10:42 PM. |
