Is the tray 150mm or 160mm long?
160mm
Can anyone who has a Ten-T tell me if it is possible to fit stndard 2.2 wheels on it?
As far as why I am asking: My club is starting a 1/10th truggy class but to keep out the E-Maxxes and E-Revos (which are labelled as 1/10th by Traxxas) we have a max tire diameter rule that necessitates standard 2.2 truck tires. |
I've been thinking the same thing. IIRC, it uses 14mm hexes, so that's one thing that'll have to be changed (to use 12mm hexes). Aside from that, the only possible roadblock I can think of is to make sure the axle carrier unit will fit inside the wheel hub.
2.2 for a 1/10 truggy, there are only two out there the ofna and the tent I am not sure to the hyper tt wheel size, but that seems small for this class.
How do you mount the motor properly via the lower bushing? Do you use a shim on the screw so it pushes against the bushing?
You arent ment to, but you can add a shim to the screw yeah. The lower bushing is designed to be a super-perfect fit so only allows the motor to swing side to side, not to tilt backwards away from the mount- the upper mounting screw pulls it tight as such.
Neil is correct
The lower bushing functions as a pivot point. We do have a new style captured bushing now, which functions the same but has a "built in" washer. The straight bushing allows easier removal of the motor along with easy gear mesh adjustment. The captured bushing retains the easy gear mesh adjustment while adding security at the pivot point, but motor removal with the captured bushing requires removing the bushing(lower screw), unlike the straight bushing. :intello:
FWIW, I've been using the regular bushing in my setup and haven't had any problems with the motor or mount...
Same here. The captured bushing is a psychological improvement - not necessary, but puts the mind at ease for the non-believers(like you once were, BrianG).:intello:
Test fitted a 1520, seems to hold fine.:whistle:
Also ordered 4000 4S 25C nanotechs and the new HK servo. Anyone busted the stock delrin gear? Think I've read that 8ight-E spurs fit, anyone tried it? Looks fairly bulletproof though.:yipi: |
Has anyone tried using a Mod1 Spur Gear instead of the Delrin Mod 0.8 gear that comes with the kit?
I'd love to use a Mod1 so my D8Te and Ten-T use the same pinion gears. Thanks, Nick |
| All times are GMT -4. The time now is 02:55 PM. |
