Hopefully you haven't updated it yet. I am looking for the Losi MRC ratios right now...
Edit: Copy and pasted from RC-Driver: Quote:
Nope, no updates until I get the data requested in this post. I usually post my intent to update and wait a couple/few days for the responses. Seems to limit the late requests...
1st - 70/18 2nd - 63/25 Now here are the internal ratios: LST FOC (this is the losi kit, also the internals of the aftershock are the same as this) - 23/22 primary 30/15 secondary The Lst and Lst2 have a manually selectable high/low internal gearing, all other lst based trucks have the FOC listed above. Lst/Lst2 low range internal gearing - 30/15 primary 30/15 secondary Lst/Lst2 high range internal gearing - 23/22 primary 30/15 secondary Also your "swap mod" info is correct. I am sure no one care about the ratios for the mech reverse, so I will not bother looking them up. |
Question brian or anybody for that fact.
On a tc5 the fron and rear diffs are 40t the 2 pulleyes atached to the spur are 20t. Would I be correct in assuming the calc inputs should look like F\r diffs: 2/1 Tranny: 1 add gear ratio: 1 spur: 80 (stock gear) pinnion: 30 (since thats what I ordered) Battery: 7.2v 6s 1.2 (since I don't have any 2s lipos yet) motor: 5400 ( 7.5 novak drift motor) wheels: 2.5 Not sure what the rest of the optional data is value wise. |
So whens the update comin?
Thanks nitro.
OK, I finally made an update:
- Added several brushed motors. - Fixed LST/LST2 transmission ratios. - Added LST/LST2 FOC transmission ratio. - Added Hot Bodies D8 differential ratio. - Added a note for the old RCM slipperential stating V1 is discontinued. - Added Mod 1.5 gear pitch. - Added Losi MRC transmission ratio. - Removed battery charger data table, selection box, and all code relating to pre-set battery charger information. - Added new feature to the Power Calculator page. Once the user enters the data into the form and calculates the power figures, it will also provide a table listing estimated pack capacities to get the same runtime at different voltages. - Removed the Sky & Technologies link (Quark) since the address is no longer active. - Removed the Beta alert on the BL Parameter Comparison page. |
Lot of updates :yipi:
I have a 775 Titan Motor in my 3906 Do I use the 10T brushed 6526 Kv rating ? 105.35 mph (169.23 km/h) The Titan 775 is closer to 1300 Kv I think |
any chance you could add the novak/speed passion "1/8" motors??
and the basic ROAR leagl ones too... |
I generally shy away from adding just any motor. This site is not affiliated with RCM, but it IS meant for the members here, so I try to stick with what Mike had. Besides, the motor list is getting VERY long. At some point, it will become very cumbersome. But, if demand is high enough, I guess I could add Novak stuff. Post things like kv, size, etc and I'll add them. |
size turn watts KV wight shaft WORTHLESS INFO
<TABLE cellSpacing=1 cellPadding=2 bgColor=#ffffff border=0><TBODY><TR height=16><TD noWrap align=left bgColor=#000000 height=16>HV4.5</TD><TD noWrap align=middle bgColor=#ffff99>3524</TD><TD noWrap align=middle bgColor=#ffff99>Sensored</TD><TD noWrap align=middle bgColor=#ffff99>550</TD><TD noWrap align=middle bgColor=#ffff99>4.5</TD><TD noWrap align=middle bgColor=#ffff99>890</TD><TD noWrap align=middle bgColor=#ffff99>5,000</TD><TD noWrap align=middle bgColor=#ffff99>8.36</TD><TD noWrap align=middle bgColor=#ffff99>5mm</TD><TD noWrap align=middle bgColor=#ffff99>Large</TD><TD noWrap align=middle bgColor=#ffff99>High / High<SUP>S</SUP></TD><TD noWrap align=middle bgColor=#ffff99> Y </TD><TD noWrap align=middle bgColor=#ffff99>Y</TD><TD noWrap align=middle bgColor=#ffff99>Y</TD><TD noWrap align=middle bgColor=#ffff99>Y</TD><TD noWrap align=middle bgColor=#ffff99>Black</TD><TD noWrap align=middle bgColor=#ffff99>Ribbed</TD></TR><TR height=16><TD noWrap align=left bgColor=#000000 height=16>HV5.5</TD><TD noWrap align=middle bgColor=#ffffff>3525</TD><TD noWrap align=middle bgColor=#ffffff>Sensored</TD><TD noWrap align=middle bgColor=#ffffff>550</TD><TD noWrap align=middle bgColor=#ffffff>5.5</TD><TD noWrap align=middle>800</TD><TD noWrap align=middle>3,700</TD><TD noWrap align=middle>8.36</TD><TD noWrap align=middle>5mm</TD><TD noWrap align=middle>Large</TD><TD noWrap align=middle>High / High<SUP>S</SUP></TD><TD noWrap align=middle>Y </TD><TD noWrap align=middle>Y</TD><TD noWrap align=middle>Y</TD><TD noWrap align=middle>Y</TD><TD noWrap align=middle>Black</TD><TD noWrap align=middle>Ribbed</TD></TR><TR height=16><TD noWrap align=left bgColor=#000000 height=16>HV6.5</TD><TD noWrap align=middle bgColor=#ffff99>3526</TD><TD noWrap align=middle bgColor=#ffff99>Sensored</TD><TD noWrap align=middle bgColor=#ffff99>550</TD><TD noWrap align=middle bgColor=#ffff99>6.5</TD><TD noWrap align=middle bgColor=#ffff99>730</TD><TD noWrap align=middle bgColor=#ffff99>3,400</TD><TD noWrap align=middle bgColor=#ffff99>8.36</TD><TD noWrap align=middle bgColor=#ffff99>5mm</TD><TD noWrap align=middle bgColor=#ffff99>Large</TD><TD noWrap align=middle bgColor=#ffff99>High / High<SUP>S</SUP></TD><TD noWrap align=middle bgColor=#ffff99>Y </TD><TD noWrap align=middle bgColor=#ffff99>Y</TD><TD noWrap align=middle bgColor=#ffff99>Y</TD><TD noWrap align=middle bgColor=#ffff99>Y</TD><TD noWrap align=middle bgColor=#ffff99>Black</TD><TD noWrap align=middle bgColor=#ffff99>Ribbed</TD></TR><TR height=16><TD noWrap align=left bgColor=#000000 height=16>HV7.5</TD><TD noWrap align=middle bgColor=#ffffff>3526</TD><TD noWrap align=middle bgColor=#ffffff>Sensored</TD><TD noWrap align=middle bgColor=#ffffff>550</TD><TD noWrap align=middle bgColor=#ffffff>7.5</TD><TD noWrap align=middle>620</TD><TD noWrap align=middle>3,000</TD><TD noWrap align=middle>8.36</TD><TD noWrap align=middle>5mm</TD><TD noWrap align=middle>Large</TD><TD noWrap align=middle>High / High<SUP>S</SUP></TD></TR></TBODY></TABLE> |
I don't use Novak anymore but I do use your site Brian and I appreciate every thing you do. :great:
| All times are GMT -4. The time now is 11:58 AM. |
