-   -   RC8T build pics are here with more to come (https://www.rc-monster.com/forum/showthread.php?t=14823)
bdebde 10.10.2008 11:48 PM
Originally Posted by entjoles (Post 221458)
do you have a link?
all i can find for the center diff mount is the same for the buggy and truggy
:oops::neutral:
ASC89322 Center Diff Shim
entjoles 10.10.2008 11:52 PM
thanks, ill check it out
Unsullied_Spy 10.10.2008 11:56 PM
http://www.losipartshouse.com/servle...im-cln-/Detail
cheesecake 10.11.2008 02:39 AM
the spacer wont make the gear high enought. the buggy has no hole for the spur gear where the truggy the gear has a hole to mount it lower. why would you need a 54 tooth spur gear in the buggy. what are you trying to do with your setup
entjoles 10.11.2008 03:33 PM
its so i can run this asap :rules: and use the motor i have (hvmaxx 4.5 - 5000kv), i need the final drive ratio around 22:1 , so with 11/54 it will be good, and the speed calc. puts my speed at 40-41mph , 4s mmm and the 4.5 hv motor in a rc8 buggy
cheesecake 10.11.2008 04:41 PM
well i dont think the gear will fit due to no cutout on the buggy chassis
Unsullied_Spy 10.12.2008 11:32 AM
That's easy enough to fix though. Use a Sharpie to mark out on the chassis where the hole is needed, then drill holes in it with a regular drill bit about the right size, then use a cutoff wheel on a Dremel to cut it all out (there shouldn't be a whole lot if you drilled it right), then just clean it all up with a grinding bit on the Dremel. Take your time to do it right and it will come out nice and probably still only take 30-45 minutes.
Bomb-Proof 10.13.2008 09:42 PM
Try the 44 or 46t kyosho nylon gear, with a 9t pinion and you will be better off.
cheesecake 10.13.2008 11:34 PM
well after the last outdoor race of the season i will be doing some modding to the truggy. so i will try to keep everyone as updated as possible
Daytona675 10.16.2008 05:12 PM
Nice build:yes:.Do you have the chocie of lay-down or upright?
http://i236.photobucket.com/albums/f.../E-RC8T002.jpg
cheesecake 10.17.2008 03:32 AM
with the rc monster plate you cant use a laydown servo
cheesecake 10.20.2008 11:38 AM
Well i got my body back and now im not sure i want to even put stickers on it:lol:
http://i54.photobucket.com/albums/g1...T/DSCF1212.jpg
http://i54.photobucket.com/albums/g1...T/DSCF1213.jpg
http://i54.photobucket.com/albums/g1...T/DSCF1214.jpg
http://i54.photobucket.com/albums/g1...T/DSCF1216.jpg
http://i54.photobucket.com/albums/g1...T/DSCF1215.jpg
cembom 10.20.2008 03:14 PM
lol just order another one. I mean if your hesitant too put stickers on it, wait till you go too drive it.
Daytona675 10.20.2008 04:24 PM
Body looks great. I saw earlier you were going to pick up a motor mount, did you ever get this? I am slowing starting a rc8t build and I ordered the mount and the servo tray looks completely different? looks like it will allow the lay down for lower cog. again body looks bad ass:yipi:cograts.
cheesecake 10.20.2008 06:22 PM
i stickered it up and yup i have 2 more bodies sitting at home im going to spray bomb them
