-   -   Neu and Mamba Max Combo (https://www.rc-monster.com/forum/showthread.php?t=5714)
Sower 02.16.2007 04:38 PM
Originally Posted by Serum
Trakpower uses a special grade of enerland cells. they are not 'just' enerland cells.
and since two trackpowers are cheaper, the answer is obvious.. :p
Right. I was actually thinking of doing that - putting two of them together would make it a 4 cell 4900. I was looking at a couple of the other 2 cell Enerlands too. Not as tempting as the two Trakpowers. What do you thik Serum - are the two Trakpowers, the Lehner 1950/7 hi-amp, and MM esc going to give me a great system that will stay cool?
AAngel 02.16.2007 09:24 PM
I don't know if this means anything, but I just tried to program my MM and when I started the app, it told me that a firmware upgrade was available. Is this the fix?
glassdoctor 02.16.2007 10:42 PM
I wish it was...
Serum 02.17.2007 04:06 AM
Nope, the update is a fix for the lipo cell count..
Yeah, the setup you have in mind will be awesome!!
AAngel 02.17.2007 04:39 AM
That's funny, because I've never had a problem with my MM detecting the cells. In fact, I wasn't even aware of this issue. We just happened to finish my friends 8ight tonight. We got the MM in from Mike today. Plugged everything up, jacked in a 4S pack and it only beeped twice. I wasn't happy, after what he had been through dealing with Finedesign. I decided to try the flash with the new firmware and all is well.
I suppose we should just keep twidling our thumbs, or perhaps just go out and buy a Quark. I really wanna get that Neu. For some odd reason, I just don't find the Lehner as appealing.
Serum 02.17.2007 05:01 AM
Trust me, once you have a lehner motor in your hands, it's sweeter than sweet. Besides its ugly sticker and ditto purple end bell, it's simple a precision produced tool..
Sower 02.19.2007 11:09 AM
I'm just curious - what about the Lehner don't you like? Other than what Serum mentioned about their disco packaging. They should put a few rinestones around it or something and just go all out.
AAngel 02.19.2007 12:38 PM
The Lehner that I was interested in was the 1940/7, but it has a 4mm shaft. If I got with a Lehner, it might have to be a 1950, just because of the shaft diameter.
Sower 02.19.2007 04:01 PM
What's wrong with the 4mm shaft? Is it pinion availability? If so, RC-Monster has 4mm pinions.
jhautz 02.19.2007 11:33 PM
mike can make you an adapter so any 5mm pinion will fit the 4mm shaft. I have one he made. It works great. Used it to figure out the gearing I want with my 5mm pinions. Then ordered the correct 4mm pinion. But you could just use the adapter permanently if you wanted to.
