FWIW, the FLM CVDs work quite well so far. And Mike has them in stock (or did when I got mine a few weeks ago).
I just caught your post on on the traxxas board. :) I've lossened the slipper a bunch and that seems to be keeping it together but I'd rather have all that power to the wheels.
I notice you seem to cruise through that grass. :) Stock tires? |
Whats your opinion on the Pro-Line Epic beadlocks? I haven't heard to many positives... How many runs do you have with them?
I've got a question for all that have these trucks.. How do they compare to the rustler? I know they look wider just wondering.
phil |
How is the hex, does it look decently strong? I'm debating a pair hence the twenty questions.
I'll have to get me a set then. I appreciate the input. :)
I don't have a rustler but I parted out my emaxx for funds for t a slash. Seems to be less fragile. That could be a result of it being a simpler vehicle. ie less parts. I like mine and am happy with the purchase. |
and this one: http://www.miponline.com/MIP/News/En..._Screws!_.html |
And I already got the FLM CVDs and they seem to be holding up well so far. They do use set screws to hold the cross pin in place, but also use a metal spring clip to help in case the pin gets loose. |
I don't like ball diffs either. But this one seems easy to adjust and it's probably lighter than an oil filled gear diff. Does look like the gear is plastic though.
Another follow-up:
I took the Slash out again this weekend for some bashing. I replaced a popped yoke on one of my sliders with the slider from my other Slash. It held together just fine for me this weekend. I really had no major issues at all except this damn thing is too fast to run WOT on bumpy ground. The only other minor observation is that the beads on the Switch tires seem to be trying to pull out of the beadlocks. They just look like they're not aligned as well as I had originally mounted them. I believe that removing the tires and taping them should cure this issue in the future. It may also help make the truck more driveable without the rears becoming pizza cutters on every WOT burst. Overall, the truck is holding up well to the power. I am definitely interested in picking up the new RPM rear bumper mount when it's available. I'm hoping that will keep it from popping off the edges of the chassis like it does with every roll over now. |
| All times are GMT -4. The time now is 10:41 AM. |
