With sensored you can have a higher rollout with any motor.
The use of 11000kv+ motors without startup issues is solved. Dragracing is much more consistant. The cheat mode, aka Boost or Turbo in other ESC's makes it possible for burst speeds at topend or at whatever rmp you which to set it at. Weak batteries need not to apply. 6S capable without mods. |
I doubt they will keep the MM. It is hard to build, very labor intensive. If the Pro is at the same price with the same power but easier to build, why have both?
so im waiting for this esc:whistle:o yes im waiting:mdr: |
So you can get a MM for $130 and the MMM for $150, logically the MM Pro will fit right in the middle? This is going to be hell for people as indecisive as I am...
Pretty simple really:
- MM for small vehicles with little mounting real estate and want to run 2s-3s. - MM Pro for similar vehicles but has a switching BEC, so good up to 6s on the smaller "HV" setups. - MMM for the bigger stuff. |
My list has been updated accordingly. :smile:
You guys forgot the sensored part.
If the MM pro is priced similar to the MM and MMM, I don't see the incentive to buy either the the MM or MMM in 90% of cases when the MM pro has all the capabilities of both (almost the MMM) and more. Correct me if I'm wrong, but the MM has almost the same number of fets as the MMM, thus nearly the same power handling capabilities. The fan and extra surface area of the MMM are what make it handle much more continuous current out of the box, but since the MMpro will have fan that is removeable, you are set for at least any 6s 1/8 scale racing setup.
I would honestly think that the MM Pro with what features it has would cost a little more than the MMM. I could have missed something and be totally out of the park on this one but just an observation. Either way, I am sure it will have a good price point and fly off the shelves.
My MMM almost never comes in with its fan on(only comes on when i plug it in) - even on a hot day. Without a fan in the same scenario, the MM would thermal(and would thermal with a fan occasionaly as well). If the MMPro has the same basic layout as the MM, I would expect similar performance. I think the MMM pro may be a good 1/8 buggy esc on 5s perhaps, but I also think it will need a milder setup to survive vs. the MMM. |
| All times are GMT -4. The time now is 02:55 PM. |
