Hey GriffinRU, I just recently aquired a Novak HV-Maxx brushless system and within minutes of running it for the first time the Magnet slipped on the shaft. As i fixed it with JB Weld( no warranty) I tried to find the sensors and couldn't. Could you explain how the sensors work with nothing to key into on either the magnet or the shaft? When i think sensors i think revo Optidrive, but i'm sure it could be a solid state setup as well. So could you please enlighten an old newb? thanks
Yeah Artur!! this would be awesome.
I would love to drive a 10XL on 18 cells sensored, it is possible to get the hvmaxx esc modified to run on an higher voltage, right? |
1 Attachment(s)
Artur |
After solving initial problems, future upgrades/modifications would be addressed as usual. :) Artur |
16 is nice. what is up with the 6cells on the capacitor side? is it a BEC issue? or are these cells used for feeding the processorboard?
Keep us updated please, this is a very interesting project. Are those sensored feigao's easy to get? |
Ok thanks, i saw that but thought you needed a rotating assembly for the sensors, like the Revo Optidrive system. But if it runs on magnetic feedback, wouldn't it be similar to a sensorless except sensorless doesn't use a circut board to detect movement?
It is possible :) but is it easy or not I am not sure, sorry for not clear answer. Artur |
Artur |
If I read correctly some where. Can't you bypass the first 6 cell group and run a ubec to power it. The run the 16 cells like in a series on the other wires. The main hot and ground wire.
There is no way to substitute built-in power for logic and brains with external power without modifications on PCB. Artur |
Ok, it is working now. Almost plug and play :)
Requires some tweaking on sensor side, I will share info with Feigao, hopefully it can be resolved. So far works as expected. Too bad its raining outside. Artur |
Well is other companies going to make a sensored esc. I would hope so. I would like to see a 8s lipo capable esc with sensored smooth running.
I have got a bunch of new stuff coming for my maxx. 977 charger, 9L and a HV-Maxx setup. I will try out the HV-Maxx and then I think I am going to try the 9L on it as well. Could be a month though, but I enjoyed this writeup Arthur.
12 Cells, 6XL, 66t Spur, 21t pinion
1 Attachment(s)
Next would be mods on ESC.
By the way do not use reverse with Novak HV-Maxx or use it carefully, because going from forward to reverse is safe but going from reverse to forward... you can snap everything in your truck with big motors :) Artur P.S. Quote:
| All times are GMT -4. The time now is 12:54 PM. |
