The truck arrived last week. It looks impressive.
http://i733.photobucket.com/albums/w...psc8da3ed9.jpg http://i733.photobucket.com/albums/w...ps934942d8.jpg http://i733.photobucket.com/albums/w...ps4e55ba76.jpg http://i733.photobucket.com/albums/w...ps3c7506ba.jpg http://i733.photobucket.com/albums/w...ps6f090447.jpg |
Installed the battery trays. I decided to keep the weight balanced and as close to the center line of the truck as possible.
http://i733.photobucket.com/albums/w...ps189c4d23.jpg |
Motor went is with no issues. The mount is nice and beefy. Conversion came with a 12 tooth pinion and locked center diff. A regular diff is also in the works.
Check out the "back bone" brace. No flex what so ever. http://i733.photobucket.com/albums/w...ps63822adc.jpg http://i733.photobucket.com/albums/w...psc0bc654a.jpg http://i733.photobucket.com/albums/w...pse9160de7.jpg |
Then came the ESC and the BEC. I also added the extra caps for good measure.
The kit came supplied with a sealed receiver box as well. http://i733.photobucket.com/albums/w...psb770d236.jpg http://i733.photobucket.com/albums/w...ps43062ed7.jpg |
The kit also includes a new servo tray. Very well made and well thought out.
http://i733.photobucket.com/albums/w...ps40550a19.jpg |
A side shot of the center diff spool, and housing.
http://i733.photobucket.com/albums/w...ps9ade7555.jpg |
Wiring buttoned up and batteries in place. :smile:
http://i733.photobucket.com/albums/w...psb2bec07f.jpg http://i733.photobucket.com/albums/w...ps85c9d616.jpg http://i733.photobucket.com/albums/w...ps53b5e2c3.jpg http://i733.photobucket.com/albums/w...psb47188cb.jpg http://i733.photobucket.com/albums/w...ps9ca66b50.jpg |
Plenty of room to work in with the customized cage installed.
http://i733.photobucket.com/albums/w...ps2580d231.jpg http://i733.photobucket.com/albums/w...psc79e9a03.jpg http://i733.photobucket.com/albums/w...ps73a5d6e4.jpg http://i733.photobucket.com/albums/w...ps584ab7a3.jpg http://i733.photobucket.com/albums/w...ps9687b230.jpg http://i733.photobucket.com/albums/w...psf4e07be2.jpg |
Ran three sets of packs through this weekend. The kit, motor/ESC performed very well. Bashing in a very large lot. Top speed is very similar to Losi 5ive trucks. Amazing low end torque. Jumps very well and controllable.
I need better tire for the loose dirt conditions. http://i733.photobucket.com/albums/w...psaa016438.jpg |
Just awesome man, I was hoping to see more of this truck.:yes:
That steering setup looks like what the Losi 5ive needs. I think a spool is the way to go, even with the thickest oil brushless motors just heat up diffs, and heat is bad! Is that an FM radio?:whip: Hobbyking sells 2.4 for $20:yipi: Get some video! |
I recall having a discussion about the performance value of a center diff as opposed to the drawback in heat when used in a 1/5 scale electric vehicle.
Thanks -paralized-.
I'm an old school, old fart. :) I have a JR radio, but it is FM...just not 2.4 I have about 30-40 cars and trucks on this radio system, so it would be really expensive to switch. I guess I'll tell Monster Mike to skip the center diff then. I will not be racing, so I guess I'm set. |
Any news if/when the conversion kit will be available?
| All times are GMT -4. The time now is 10:28 AM. |
