-   -   Couple of issues wih my Mamba Max (https://www.rc-monster.com/forum/showthread.php?t=5372)
rchippie 03.03.2007 02:12 AM
Originally Posted by squeeforever
Personally, I think an 8XL might be a better option, but it could still possble be an ESC problem. I would stick with an XL for sure. Perhaps you can gear even lower? Try the Century 9T pinion. Let us know how the fan helps!
Squee & glass doctor thank's for the repliy. If i stick with the 7xl i really could'nt go to a 10t pinion because i would loose to much speed. Why would a 8XL be better in your opinion ?. I do plan on using the fan in my next testing session.
squeeforever 03.03.2007 02:23 AM
The 8XL will pull less amps. Simply as that. So the ESC will heat up less. It's like running a 10L instead of a 9L. Also, it will allow you to gear up as well.
rchippie 03.03.2007 02:26 AM
Do you have one you would like to trade foar a 7XL ?.
squeeforever 03.03.2007 02:29 AM
Unfortunately I don't. I only have a 10XL.
rchippie 03.03.2007 02:37 AM
How would that motor do on 14 cells in my setup ?.
Serum 03.03.2007 02:50 AM
The 10XL has got a 1502 kv range.
I personally loved the power of the 7XL in your Mugen, (and the temperature/ runtime)
So the 7XL would be an okay choice IMO.. isn't it an option to get a 9920?
coolhandcountry 03.06.2007 09:43 PM
Sounds like you got more run time without the fan this time.
The 8xl may help. What about a 9xl? I may be able to help you in that area.
rchippie 03.06.2007 10:17 PM
What up leroy :eek: .
It was slighty cooler when i tested plus it was not at the track it was in front of m house. someone here is going to buy my 7xl . I'm gonna call you .
rchippie 03.08.2007 01:12 AM
Trying a different ESC
As you all know im having trouble with my MM thermeling. So i desided to try my warrior instead. So far so good. I got 1 test run in front of my house with no issues . Im going to the track for a better test.
rchippie 03.08.2007 06:30 PM
Same Problem
I just got back from the track. My buggy still thermals even with my warrior.I was running the same gearing 11/51. So after talking with mike on the phone im either going to buy a 8XL or a LMT 1940 8T to run in my buggy. Mike does'nt have the 1940 8T in stock yet so i'll have to wait . If someone had a LMT 1940 8T in excellent condition plus 20 or 30 bucks i would strongley consider trading my EVO for it.
Sylvester 03.08.2007 08:02 PM
Wow hippie! Giving up your evo for a motor.. ive got a lehner 1950 7t.. no, i cant... :) Any pics of the revo?
rchippie 03.08.2007 08:24 PM
I have a buyer for my MM & 7XL, so i probably wont have to give up my EVO for a motor. But im thinking of selling it so I'm working on pics.
