I have the Feigao 7xls in stock. I can get the wanderer versions of the above listed motors for around $100+/-.
I let you know something as soon as I know.
alrighty! Whenever you are ready.
I have a favor to ask. Do you have any specs on the 8 and 9 xl? Also what exactly is a wanderer version? You can email or pm me.
8xl - 83 amps, 2084 rpm/volt
9xl - 74 amps, 1853 rpm/volt The wanderer version is made for BK Electronics with better bearings. |
And the extra bonus is, that they come in blue instead of purple.. )(a bonus to me..)
I like the blue to serum. I running the blue and sliver look. They work with the schulze. I pretty sure they should but just want to make sure.
Hey mike. The motor you talking about. Is that the 20 series.
Yes, the wanderer 20 XL serie. I too like the blue over the purple..
1 Attachment(s)
That was the reason i bought the nemisis. It had the blue.
Hey MIke. I need to up grade my rears. Are the Hybird rears with the 7.5 gears worth upgrading to? I have tore aother set of spiders out.
I use those hybrids too they are great. (with 8 spiders) be sure to change your gearing, because they have got a larger ratio than the stockers..
I like the UE cups over those hybrids though, they give you a better change to shim the diffs propperly.. What diffs are you planning on using? |
I not sure serum. I wanted some opinions on what to get. I am running the combo bulk now form fastlane. I like them and wanted to get another set if i change.
Just also make sure you change both diffs (can't run 7.5 diffs in the rear and stock diffs in the front). The 1/8 buggy diffs will end your diff problems if they are built correctly.
can you get the entire kit mike. if so how much? pm or email don't matter
| All times are GMT -4. The time now is 06:44 AM. |
