-   GorillaMaxx (https://www.rc-monster.com/forum/forumdisplay.php?f=16)
-   -   New products-Site Closed (https://www.rc-monster.com/forum/showthread.php?t=5604)
suicideneil 04.08.2007 06:29 PM
As with everything in life, they had to make a trade-off. The chassis is now slightly thicker = slightly stronger, and only a little bit heavier than before. It will still handle better than any stock type chassis due to the lowered CoG. I would have thought making the chassis from 7075 alloy would have been the best bet- much stronger but same weight as before, although a bit more expensive..... whatever.
coolhandcountry 04.08.2007 06:38 PM
They made the chassis plate thicker for little stronger. The problem i see
is they didn't fix the x braces where they bend. That is my complaint.
squeeforever 04.08.2007 07:15 PM
Sorry suicideneil, the Racebombs are no more, and hard to find. I should have one with the 7075 top plate (#5 of 10 made) in the mail pretty soon though. :D
suicideneil 04.08.2007 08:41 PM
Typical squee, nicking the last one.... As for the x-brace issue, yeah, it is quite annoying that they didnt adress the bending issue. The obvious problem is that the motor mounting screws go up through the x-brace so they cant put a bar across that area to stiffen it up. The only solution I can think of are some kind of braces that run along parallel to the x-braces, either on the inside or outside if you see what I mean, along the whole length of the chassis, and are bolted down onto the battery plate. That way they wouldnt be in the way of anything, and would add much needed stiffness.....
rchippie 04.08.2007 09:32 PM
Maybe not :eek: .
squeeforever 04.08.2007 09:41 PM
Originally Posted by rchippie
Maybe not :eek: .
Say what...
coolhandcountry 04.08.2007 09:43 PM
Yeah! What?????
rchippie 04.08.2007 09:44 PM
Say what...
JK it's all good :005: . Lets just say cory will have his bomb very soon .
squeeforever 04.08.2007 09:57 PM
:) Can't wait.
rchippie 04.08.2007 10:04 PM
I heard with the g2r there was a problem with the shock mounts or something similar how did this affect the truck ?. If this is true has it been fixed with the g3r ?.
squeeforever 04.08.2007 10:17 PM
Yup. Its fixed on the G3R.
rchippie 04.08.2007 10:30 PM
So that means the new chassis has the same FR kick up & RR antisquat as the stock chassis ?.
squeeforever 04.08.2007 11:16 PM
I'm not exactly sure on that. I would imagine it does, but you might want to contact George.
Dafni 04.10.2007 08:49 AM
Originally Posted by zeropointbug
How do you know that about the milled slots Dafni?
The Monster told me :)
suicideneil 04.20.2007 09:24 AM
NEWS: spares are now available on the GorillaMaxx site for:
G3 chassis (cf & aluminium)
G3.3 suspension
The single motor mount is out of stock- suprizingly....
ClodMaxx 04.20.2007 09:38 AM
they probably only made one, and i was the one dumb enough to pay $40 for it. :005:
