What Neu are you running and what motor mount is that? I see you are using motor brakes as well? What do you think of the setup and what velocity are your oils.
Thanks! |
Nice action shots. You should race towing the trailer so it is fair for the nitros. :lol:
Well took it down to the track today. I changed the front shocks to a #55 piston. It was a very humid day, I was sweating pretty bad at the track. Motor temps were between 150F - 163F and the ESC & Battery was 112F. Not many pics this time. 1st picture is just my son watching me fly around the track making sure the buggy is running right (soon to be pit crew). I took the video camera down aswell but went to record and realised that the battery was flat.
http://i110.photobucket.com/albums/n.../110908_01.jpg http://i110.photobucket.com/albums/n.../110908_02.jpg http://i110.photobucket.com/albums/n.../110908_03.jpg http://i110.photobucket.com/albums/n.../110908_04.jpg http://i110.photobucket.com/albums/n.../110908_06.jpg http://i110.photobucket.com/albums/n.../110908_05.jpg |
what gearing are you running now?
I have the same setup geared 13-48 and my motor runs about 170-180 after 15 minutes. and my 4s 5000 pack hit voltage cut right at 15 minutes.I'm thinking it's undergeared. with the same setup on 5s temps are the same but runtime is about 20 minutes |
so what gearing are you currently running?
thanks,what I needed.
I have been running 13-48 on 5s,this weekend I tried 4s with same gearing and was slower on straight,but runtime went down and motor temps stayed the same |
good info
Well had to happen sooner or later. Playing around in the backyard, came in to check the temps and notice the fan not working. Had a good look in and saw that 3 of the blades on the fan had snapped off. MMM still runs though and I have a spare Novak fan sitting in the cupboard. Just got to decide what to do - Send it back to CC or just put the Novak fan in
that sucks,my mmm broke the fan plug off of the board already.
Took the cover off tonight and removed the blades. Fan still works and MMM still work fine. Thinking about trying the MMM without the ext. bec and see what happens
Just finished up my e-8ight using the tekno conversion.. WOW awesome! I've got the MM esc w/ fan and ccBEC (4s config). Gearing is stock spur (48) and 16t on the e-clutch. No temp issues and she runs great! Motor is the Medusa v2 2000kv 60mm.
7,10,3 for diff fluids 50wt w/ Green on front shocks 35wt w/ Black on rear shocks She runs great and I was owning the nitro's today! |
| All times are GMT -4. The time now is 03:32 AM. |
