Oh yeah, i think a warriro can do taht. Also, when i charge my limn, my Power supply only goes off when i charge at 2500mah. Not at 250mah. Does that mean the power suply is crappy and cant handle taht type of amps? I rmember seeing a cheap Power supply. Some1 posted it up. Its eitehr sly or sque or metalman who mentioned it. Any1 remember where it is? I couldnt find it on the search tool. HIghest mah i can select without shutoof is 2000 :(
Yes, the 9920 can do that. Also, it's possible your PS is not putting enough to the charger. I would talk with Brian G on that
The lisaver has a few warnings before the wide open reverse.
WTF?!?!?!? one pack is at 2.75Vs! HOW DID THAT HAPPEN!?!? mY OTHER PACK CHARGED FINE! THIS ONE HAS AN EROOR!! IS my PAC ARELADY RUINED!!!
Take a pill
To Kill Myself> T His Is Bullcrap! Wtf!
Nah, to relax. Getting pissed off will not help. Take it from the pro at doing it....ME! There is way to bring the charge up. From my understanding, you can set your charger on nimh at like 1.0 amps maybe less and charge for a minute to bring the voltage back up, then, set it back to lipo and try to charge it again and see what happens. I think this is the way, the amps might be a lower setting though. Anyone want to chime in and correct me if I'm wrong?
Coolhand told me to make a Y harness and charge both packs up that way. thats what i did and its able to charge now. Lets hope it'll bring up the voltage!
It should, I would keep an eye on them though
it worked nicely! thx leroy!
JUST BOUGHT A LSP! Im thinking about buying this good deal on another brushless system. Maybe run brushless in unlimited and mt classs? HOw much does teh BPP lsp conversion cost?
| All times are GMT -4. The time now is 12:28 AM. |
