-   -   8xl to hot under 22/54 gearing ? (https://www.rc-monster.com/forum/showthread.php?t=10022)
speedy 02.06.2008 06:39 PM
Hi !
I have a question about heat and gearing of feigao motors !
Why does my 8xl get way hotter with 22/58 gearing than 22/54 gearing ? choudent a lower gearing make it run cooler and lower the ampdraw ? My mm-esc bearly get's warm after 20min runs but the motor gets way hotter ! maybe 60-70 celsius, but it runs cool on the higher gearing! 20-40celsius
Another question: Will my e-maxx be to heavy with 2x2s 12000mah lipo's ?
by that i meen if it will break easely or feel slugish beacause of the weight of the battery's ?
lutach 02.06.2008 07:07 PM
Originally Posted by speedy (Post 147151)
Hi !
It might be going faster and you might be giving less throttle? TBH I would love to know that as well. I'm not stealing your thread btw. If Feigao likes to run big pinions, I will have to get my 22 or even 30T pinion out for a spin :lol:.
speedy 02.06.2008 07:16 PM
no i give about the same amount of throttle with both gearing config's :) mabe a litle more with the higer gearing because the ttruck accelerates slower with that gearing :intello:
MTBikerTim 02.06.2008 07:27 PM
General rule if everything is cold and the motor is hot you need to gear up. This is exactly what you are seeing. You need to get a bigger pinion by the look of it.
suicideneil 02.06.2008 07:35 PM
Bigger pinion or smaller spur... or both. That could be difficult though.
speedy 02.06.2008 08:06 PM
it runs fine with 22/54 gearing :lol: i just wondered why the motor get's hotter with a lower gearing !!
zeropointbug 02.06.2008 08:20 PM
It's because the motor is running at a higher rpm/lower 'load', which is exactly what the Feigao's don't like. They are quite limited in this regard, as you only have a narrow range of gearing options.
