-   -   Get hot.....No brakes! (https://www.rc-monster.com/forum/showthread.php?t=1003)
rcjmaxx 08.10.2005 09:53 AM
I've got a TXT-1 monster truck with a 9L/9918 combo,the truck weighs 14lbs with 14 cells and geared 65t spur 16t pinion for topspeed running.Recently after 3 passes the controller temp hit 170 and it had no brakes,after slowing down reverse is there but still no brakes.Because the batteries were dead I called it quits.The next day before taking it out I reprogramed the controller,and everything was back to normal.But once the controller hit 165 degrees again no brakes.After cooling down I drove it and had brakes again.Throughout all this the truck never thermaled.Is this odd? Are these temps TOO high for this controller? Thanks for any info.
Serum 08.10.2005 12:44 PM
Sounds like the familiar problem..
discussed here, here and here
camra88 08.11.2005 11:59 PM
I have this problem somtimes. But when i unplug the batteries, and then plug them back in, the brakes are restored. The breaks only go out in the forward motion. The reverse brakes always work.
rcjmaxx 08.12.2005 03:43 PM
This 'unplug then replug' is temperary,correct? What about long term? Is there a solution?
squeeforever 08.12.2005 06:32 PM
i would put a fan on it and or change the gearing.
captain harlock 08.12.2005 07:40 PM
The TXT-1 is pretty heavy and I would go for 14 teeth pinion to increase torque since this truck is a rock climbing machine that needs huge amounts of torque and the drive train is made to meet such applications . Use a cooling fan, too, like Squeeforever suggested and REMEMBER that the TXT-1 is a super heavy truck that is not suitable for racing. Enjoy crawling, RCJMAXX.
rcjmaxx 08.12.2005 09:57 PM
This TXT has never seen a day of rockcrawling.I built it for topspeed running from day one thats why I choose the 16t pinion.I just got a 14T in the mail from Mike that I will be trying out.Since so many of you mentioned a cooling fan,that will be my next move.
captain harlock 08.12.2005 11:48 PM
You should have checked the truck before buying it. It is not near the E-maxx in terms of speed and pace. Though I have neither of them, the design of the chassis and drive train give you a clear idea about each truck and if you want speed, then you should've gone with the Maxx unless you want to pull the TXT-1 into a level of speed that it can't reach with out a decent powerplant which is the brushless setup that is.
rcjmaxx 08.13.2005 09:33 AM
I own both an Emaxx and a TXT-1.I agree with you that the TXT-1 is not designed for "Emaxx type" duty,but I do enjoy the challenge.As I stated earlier I will adjust the gearing and add cooling fans to see if these help.
Serum 08.14.2005 04:51 AM
Please take some time reading the threads i posted, it will take away all your questions.
