ESC idea for brushless revo
MGM 8018 car. ill buy it off of icare-rc.com
here is a link http://mgm-compro.com/index.php?tid=...018-3-car-boat the setup will be 5s flightpower 25c mega 22/35/2 17/38 gearing here is the data Differential Ratio: 2.8461538461538462 Transmission Ratio: 2.111111111111111 Other Ratio: 1 Spur Tooth Count: 38 Pinion Tooth Count: 17 Total Voltage: 21 Motor KV: 1500 Tire Diameter (inches): 6 Tire Ballooning (inches): 0 Motor Current Draw: 60 Motor coil Ω: 0 Spur/Pinion Ratio: 2.24 : 1 Total Ratio: 13.43087 : 1 Tire Circumference (inches): 18.85 inches (478.78 mm) Total Motor Speed: 31500 RPM Vehicle Speed: 41.86 mph (67.25 km/h) Effective Speed Rate: 1.99 mph/V (3.2 kmh/V) Estimated Adjusted Speed: 40 mph (64 km/h) - 5% loss Effective KV Value: 1500 Motor Torque: 0.28 ft-lbs Final Torque: 3.78 ft-lbs Final Power: 1260 watts (1.7 HP) are the mgm's as smooth as the kontroniks? |
A 5s battery won't hold 21v while driving at 40mph. It will only be 21v off the charger with no load on it. For the calculator use 3.7v per cell or less.
| All times are GMT -4. The time now is 12:52 PM. |
