CRT.5 RCM Ext chassis and othe Q's
Alright, so my e-revo is nearing half completion, so naturally it's time to start thinking of another project :P
Alright, part 1) I can't figure out myself stems from this: I have 2 3s packs (4000mah 20C), currently I run them in my rustler (MM 9L) and will run them in series in my revo (turnigy sentilon 100A HV, 11XL). so naturally I'll want to use them in my crt.5 conversion too (just the single 3s packs, no crazy power goin on here!). So now for the actual question what are the longest batteries you can fit in Mike's chassis using the battery bar etc it comes with? I think mine is about 150mm long (don't have it handy to measure). 2) What will require more grunt out of my extended CRT.5 and my rustler? I'm thinking of either buying a velineon or sidewinder 4600 combo - so even though I could figure this out myself when the time comes, which would be better suited to what do you think? (out of veli3500/sidewinder4600 and MM+9L). and 3), I've heard of a lot of people using 1/10 2.2 rims on their CRT.5's - mainly nitro rustler rears though. Does this mean my millions of e-rustler rears can be used on my CRT too? or will the offset on the e-version be too narrow? edit: oh and while I'm pickin all your brains, whats so good about that kyosho spur that everyone loves using? Cheers Sam edit2: just realised I can get the motor mount on its own... Anyone got any ideas how big of a battery will fit on it if I fashion up my own tray? Cheers |
The maxamps 5000s fit fine on a stock chassis... the 9L will give you more torque than a MM.
I'd just pick up a sidewinder ESC or just steal the combo from the rustler - you won't use it much after the CRT.5 anyway. 2.2 works fine - personally I like the traxxas 2.8s. I think for body clearance I think you need the offset - so you can still use the tires just need to swap them to front wheels... |
Cool cheers. Any tips on de gluing tires? I've been wanting to swap all my rustler rears onto front rims for a while so I could do the nitro rustler rear arm/toe in mod.
In a saucepan with rolling boiling water for 10-15 mins a side!
Don't let it boil dry or you wife will get annoyed! trust me i know! |
Here's the bottom line for me and a few others I've seen. In the CRT.5 lighter is better unless all you want to do is make videos of your car flipping over backwards or making speed runs on the street. If you want a car that will run with a 10th scale wheeler (very capable cars) then you need to keep it light and keep all the parts on the chassis. Long batts require you to mount items above the chassis and throw off the balance. Mike's intention of using 100mm long maxamps packs works very well for balance and handling. Plus the Maxamps packs in that size are their only 20C pack. Very powerfull for the weight. |
I could be wrong, but recently on the RCM maxamps forum someone asked if Maxamps was going to start making any 20C batts and they replied that they currently did, but they were the 2100/4200 model only. Maybe I misunderstood. EDIT: I just checked the post and it was for 25C batts and they are the 4200 and 2200 that come with 25C. http://www.rc-monster.com/forum/showthread.php?t=9808 |
If you look at their site, they sell 2s2p 20C ratings as well. I wasn't sure if you meant that particular size or all around for the rating. :) If you meant all around, most of their batts are 20C
So how much leeway do you have on the rcm chassis? I was looking at some zippy-r packs that area 2200mah 21C and 109mm long. Either that or regular zippy 2100 25C that's 100mm long.
If you talk to people at fp/tp the cells are the same in the new packs, they do alot of testing, and the cells would do 25C easy, so they just moved the rating up So yes, they were under rated.. |
Heres a shot of the battery area and strap: http://i206.photobucket.com/albums/b...p/DSCF1804.jpg |
Still not too sure about the 20c rating of some of maxamps cells, especially the 3000 cells. Those cells only seem to be good for 45-50amps continuous before they heat up excessively or puff! They de-rated the 10000 cells to a 10c rating from a 15c rating. I can say from experience that the 10000 cells we never 15c, not even on a good day. |
I just hate to see a new person make the same mistakes I did, mainly due to bad info. |
| All times are GMT -4. The time now is 03:35 PM. |
