Mamba Max with a 4s
Is a BEC needed to run a MM with a 4s setup, it will go in a Rustler VXL, looking at running a Neu 1509/1.5y
Yes sir.
yes. rx pack or BEC required.
Good luck on taming that beast!!!!
What will actually happen if using the MM on 4s WITH bec ?
I got a new in the box MM that I am about to sell and I need test the MM before selling it. Would the MM survive a "wheels in the air" test with a Feigao 9XL on 4s and bec wire still connected to receiver ? |
Yes, just don't use the steering servo at all if for a short time. It's the current draw coupled with a high differential voltage that heats them up.
As I said I only need to test / arm the MM. BTW I might be stupid here, can I test the MM with Feigao on 2S ? (I do use 2S in serial normally) |
2s should be fine if you just want to see if the MM works.
Thanks !
| All times are GMT -4. The time now is 09:45 PM. |
