-   -   mm-probs ! (https://www.rc-monster.com/forum/showthread.php?t=10072)
speedy 02.08.2008 03:22 PM
mm-probs !
if the leads on a mm-esc flashes and the motor woun't run, whayt coud be wrong. It's my friends esc, and he coud drive his buggy for like 5mins and then the esc shutdown for some reason ?
MetalMan 02.08.2008 07:21 PM
Does it smell like burnt electronics? Is the voltage cutoff set higher than the voltage of the battery? Have you tried a different radio, or reversing the throttle channel?
lincpimp 02.08.2008 09:53 PM
Make sure that the connectors between the motor and esc are clean and tight fitting. I have had a variety of issues that were traced back to those connectors.
