dual brushless motors
just had a question. if i use 2 brushless motors do i need 2 esc's or can the motors be wired together to go to one esc.
thanks |
two esc's...
Unless...
depends on how big the motors are and what esc you are using , you could use up to 700 size motors on a evx esc.
Why not just size the system properly for one motor and be done?
you could use one, but the motors would need to be identical and timed to each other. Not that easy to do, but its been done.
I agree. one properly sized motor is more efficient and just as powerfull. |
But two gets you 'cool' style points...
:P :D |
reason for 2 motors is cause im going to start building a truck and im going to enter the worlds fastest rc car challenge.
ok and thanks you guys answered my question. |
Well, that does change things though, since you are building a truck for a speed record. To find a single motor as powerful as a couple feigao XLs, you'd want something like a massive Neu or lehner costing 10 times as much, and esc costing.... I wouldnt like to guess. JohnnyMaxxima has a Gorillamaxx based truck with twin 7XLs running on 5s each- and Bk9920s I think it was-that should be a good point of reference for you.
steveo - evx is not a brushless controller it is a brushed controller...
Jef - I guess you could ensure that the rotor was at exactly the same point... I suspect it would be difficult to achieve with variation between motors etc |
Dual BL will not have that much of a gain over single BL, considering the extra weight involved. With dual BL, you pretty much need twice the batteries as a single motor.
My Savage will be entering the competition, with a single KB45 10XL (1200 kv) running on 10s2p A123, with a CC Phoenix-HV110. It's geared 20/46 with a center diff (no tranny), for a theoretical top speed of about 65mph. I haven't reached top speed yet because the suspension is too soft and the oil in the center diff isn't thick enough. |
ok now would a xl motor push our more power then a L motor?
For continuous usage, yes. At the same power level, a shorter motor will generate more heat.
so if im only using it for a little bit of time could i use a L motor.
i would stick to one larger motor
what are you running this in? a large Neu motor should work wonders for speed records |
| All times are GMT -4. The time now is 02:02 PM. |
