-   -   losi 8ight suggestions (https://www.rc-monster.com/forum/showthread.php?t=10183)
satttheman 02.13.2008 11:05 PM
well im goin to my lhs tomorrow and do a 8ight conversion. and i want some input on wat setup to use.
setup1:
9xl
mgm16018
5s 3700mah
13-14 tooth pinion
setup2:
7xl
mamba max
3s 5000mah
17-18 tooth pinion
these buggy is goin to be for racing only no bashing so i could get the speed i'd need on 3s at the sacrifice of runtime unless i pickup some new batteries. the apache 5s might just be all around better but im not sure so i need some input.
lincpimp 02.14.2008 12:06 AM
Go 5s it will run much cooler and will be easier on all of the components.
3s 5k batts will not have enough power to run a 7xl in this buggy. Plus it will run hot!
satttheman 02.14.2008 12:22 AM
yea ill prolly just run the 5s it would have enough power on 3s but it def would run hotter thanks will post pics im goin to buy it and convert it tomorrow hopefully while im at the shop to show all the no believers aka the nitro guys
BP-Revo 02.14.2008 12:34 AM
To be honest I'd do a 4S setup with a Mamba Max ESC and a Neu motor.
But of the two choices the 5S would be the better setup.
satttheman 02.14.2008 01:02 AM
might try that too tomo but i dont have a 4s lipo so i might pick up two of those 2s 5000mah losi batteries and try them. good job BP-Revo that might be the winning setup plus my car and batteries will match LOL
lincpimp 02.14.2008 01:24 AM
What kind of batteries?
If you are going with the flightpower 3700 25c pack, you would have 92 amps continuous. At 18.5 volts you have around 1700 watts.
On 3s 5000 25c packs you have 125 amps. At 11.1v you have 1400 watts.
Plus the 9xl on 5s will be at a better max rpm, around 34k.
The 7xl on 3s would be around 26k max rpm, which would require taller gearing, thus causing more load and heat. The 7xl is a good 4s motor, when geared down.
So the 7xl 3s combo will require more power, and the battery will have less ability than your proposed setup. Plus the mm will not like that either.
Your cheapest way out would be a 4s setup with an 8xl. Some trakpower lipos, or a 4900 4s flightpower would be optimal to power that setup. A mm with an external bec would work with that.
5s is a big step up from 4s, much better temps and power, plus less load on the batteries. Amp spikes will be less too.
satttheman 02.14.2008 01:36 AM
apache 20c batteries its not really about the money i just dont like to wait for anything i made up my mind that i wanted one and i have to have it those to setup were based on wat i had thats new and unused but ill prolly try the 5s and than the 4s but ill have to see wat packs cause they have the losi's there i hate to wait for anything i need everything asap. i really started think about the 3s after talkin to mike about my buggy.
satttheman 02.14.2008 10:17 PM
http://i97.photobucket.com/albums/l2...g/8ight004.jpg
http://i97.photobucket.com/albums/l2...g/8ight002.jpg
http://i97.photobucket.com/albums/l2...g/8ight001.jpg
http://i97.photobucket.com/albums/l2...g/8ight005.jpg
Cloak 02.17.2008 02:29 PM
What size pinion are you running? I just ran my 4s/8xl/mamba max and man, the motor got HOT (200+F even after about 5 minutes of running it).
satttheman 02.17.2008 08:52 PM
im running a 14 tooth. wat size r u running and wat kinda of batteries
satttheman 02.23.2008 05:48 PM
i run it today and its sick i changed the gearing to 18/48 cause 35mph looks very slow goin across a parking lot LOL.
here goes some more pics of my 1/2hr conversion
http://i97.photobucket.com/albums/l2...8ight-b001.jpg
http://i97.photobucket.com/albums/l2...8ight-b002.jpg
http://i97.photobucket.com/albums/l2...8ight-b003.jpg
http://i97.photobucket.com/albums/l2...8ight-b004.jpg
http://i97.photobucket.com/albums/l2...8ight-b005.jpg
http://i97.photobucket.com/albums/l2...8ight-b006.jpg
http://i97.photobucket.com/albums/l2...8ight-b008.jpg
http://i97.photobucket.com/albums/l2...8ight-b009.jpg
enjoy!!!
check out my muggy suggestion post i want some opinions on a setup for it.
