-   -   Best way to secure the pinion gear? (https://www.rc-monster.com/forum/showthread.php?t=10210)
fkadir 02.15.2008 10:05 AM
Hi Guys,
Whats the best way to secure the pinion gear to the shaft?
I have tried using locktite but the pinion gear still became loose after about 30 mins of bashing. :whistle:
Dafni 02.15.2008 10:17 AM
Locktite, flat spot on the motor shaft, and the kung-fu grip on your wrench.
BrianG 02.15.2008 10:36 AM
Yeah, the flat spot is an obsolute necessity IMO. If it's a Neu, cover the end holes with tape or something and then use a dremel sanding wheel to grind the flat spot.
