Brushless Pinion and others.
I am not sure if i am in right section but here it goes
1) How long is Mod 1 pinion is, the one that are sold on this site? (as in length wise) 2) Would carbon Fibre motor mount plate be good alternative to alumiumum for heat dispensation ? I hope someone can answer those question. |
1) I get 12mm for the length.
2) no, aluminum is a better conductor |
But... imo it doesn't matter that much. If you want to draw heat off the motor you can put a fan on it and also have it touching the main alum chassis. (could even use thermal paste etc..) |
| All times are GMT -4. The time now is 01:00 PM. |
