Polyquest battery tray
I was just wanting to know the dimensions of this tray(lenght, width, and depth). I have some true rc batteries and they measure about 50mm wide by 150mm long. Wanting to know if they will fit well. thanks a lot
The tray inside dimension is almost exactly 45mm wide x 165mm long. Its a snug fit on the polyquest packs in the 45mm direction. Inside depth is 18mm but the battery can be as tall as you want it to be. If the TrueRC pack is 45mm or less in the thickness dimension you might be able to put it in on its side to make it fit. |
| All times are GMT -4. The time now is 06:29 AM. |
