Motor/ Esc Question
Does anyone know if you can use the Mamba Max Esc with two brushed motors?
it should work fine. this is the plan I have for my crawler. wire both motors positive side to the red esc wire, negative side to the black esc wire and seal off the white wire. Set the esc to brushed mode and it should work fine.
Okay cool. I am planning on buying a Gmade G1 and was wondering how a MM would work with a two motor setup. How many cells or what voltage do you plan to run? I have seen some people use a 6 cell pack but that seems like it would not be enough.
Yes...it has no motor limit when used with brushed motors.
i'm going to run 3s or 4s lipo pushing 2 holmes hobbies 10t cobalt puller motors in a 1:6 tuber\scaler.
I was just thinking about doing the same (two brushed on MM) if i can figure out why my MM is acting up. Glad to hear someone else has tried it.
| All times are GMT -4. The time now is 10:30 PM. |
