FLM Pede parts ???'s and shipping costs ???'s
Hi I already tried posting this in the FLM forum, but that section seems to get little traffic compared to the rest of the forums.
I plan on buying most if not all of the FLM electric Pede parts at the end of this month and just have a couple of questions. The first question is what is the main advantage/disadvantage of the standard vs. extended length arms? Is there any reason NOT to go with the extended arms for more stability like CVD/turnbuckle/stock drive shaft problems? The second question is I was wondering if I should keep the stock plastic chassis braces or put a Swami wheelie bar on the rear and a New Era brace on the front. Will an all aluminum chassis and braces bend into scrap with no points on the chassis to give, or is the aluminum durable enough for regular bashing with no insane jumping? My final question is if there's any easy way to determine shipping costs for items I order now and in the future without having to post/email everytime. My zip is 97225. Thanks |
The stock plastic braces work just fine, but FLM is making a set of aluminum braces, though, which I will offer in a complete kit(chassis, braces, tranny, arms, bulkheads). The chassis holds up fine with the plastic braces to whatever you can throw at it.
I like the regular length ams myself. they are sized to allow the same front and rear wheels and allow use of any driveshaft that is designed for the pede(like cvds). The wider arms must use sliders, which would be a bit weaker when stretched out. For shipping, for all the pede parts, the shipping won't exceed $7.70 to anywhere in the US. Most likely the cost would be under $6. |
| All times are GMT -4. The time now is 09:43 AM. |
