what motor with a 7020?
i was wondering what would be the best motor to run in an e-maxx or a electric revo if i was running an 7020? i already have a xl3100 and 9920 but the xl3100 is a lot of motor more a track and i have the chance to get a 7020 because i had to send in my 9920 for repair and they sent me a new 7020 instead of a 9920 and i can get the 7020 at a little bit of a discount. i was thinking a feigao 10l or a lehner xl2400.
How many cells.
Thank you, Promod |
12 or maybe 14
Its really going to be hard to keep it below 70 amps. I don't have a huge amount of experience with 12 and 14 cells. From testing using the Eagle tree an XL 3100 on 12 cells will peak at 115 amps and pull almost 80 constant. Also tested on 12 cells were 9L,7XL and basic 4300. All pulled about the same amps on 12 cells as the 3100 if you can believe that.
Its hard to say which motor would pull less than 70 amps constant. Maybe a slow turning basic motor? Sorry I can't be more help. But the 9920 would be a better choice for the E-maxx. Thank you, Promod |
what about like a 11l or 12l nemesis on 12 cells?
| All times are GMT -4. The time now is 09:27 AM. |
